Distributor question
quick 52
posford
How good is the stock distributor ? Should I go with an MSD Pro Billet or would a stock one be o.k.. This will be on my 533 P51 headed truck pulling engine ( hoping for around 850 hp ).
posford- Posts : 90
Re: Distributor question
i seen a few big inch motor running them and it seem to work for them. myself im running a reworked stock ford and dont know if a msd unit would make more power or not. they are not as easy to curve the advance as a msd. there is a post somewhere on reworking it thats what i used or just google it
quick 52- Posts : 612
The stock Duraspark unit works well. Mine is locked out at 34-36 ish degrees of timing and my ignition box pulls 20 degrees out at the start. Works fine for me.
jbozzelle- Posts : 3705
the msd has the same stuff in it your stock one does,or a new made in china part. the stock one will work as good,IMO
Thanks guys, I think I'll pick up a reman stock duraspark.
posford- Posts : 90
posford wrote:Thanks guys, I think I'll pick up a reman stock duraspark.
Don't forget you'll need a Bronze Gear (If you Running a Roller Cam) and Connector for the MSD Box.
The MSD distrubutors aren't a bad deal..... once you figure everything you'll need whit a factory one.
But the Factory ones do work just fine.
dfree383 wrote:posford wrote:Thanks guys, I think I'll pick up a reman stock duraspark.
This is not always true, the cam manufactures will tell you what you need.
fordman50- Posts : 32
» MSD distributor for EFI\TFI
» MSD Distributor to replace Duraspark Distributor?
» stock distributor vs msd distributor
» msd distributor in 460 block
