MSD Distributor to replace Duraspark Distributor?
Is there an MSD distributor that will work in place of the Duraspark distributor and still use the Duraspark module?
I noticed MSD is only 2 wire and Duraspark is 3 wire but that is only a ground which can be arranged.
IIRC someone once posted the pickup was the same.
Re: MSD Distributor to replace Duraspark Distributor?
Yes, look at their web page...It even shows how it is connected.
Dave C.- Posts : 1268
» Will a 351W distributor work in a BBF?
» msd distributor on duraspark ignition?
» Rear main seal replace
» Fuse box. How to replace it?
» stock distributor vs msd distributor
