Eagle Rods
+12
Mark O'Neal
466cj
Barney
16 posters
Page 2 of 2 Previous  1, 2
Eagle Rods - Page 2 Empty Re: Eagle Rods
Post  Barney May 25th 2012, 6:16 pm
Barney wrote:Rods fail for a number of reasons, an yes often on decel and free rev such as a broken drive line part, or light load in a burnout box.
Barney
Barney
Post  Lem Evans May 25th 2012, 6:51 pm
It is agreed that the "light" load in the burnout box does the rods/bolts no favors...but... i.m.o. the stuff really hits the fan when the driver chops the throttle blades completely closed directly after the exit of the 'box' while the engine rpm is still high [more than likely too high].
Post  Barney May 25th 2012, 7:00 pm
Yep, and when you release the lineloc and the RPMs sky because the burnout rev limiter is no longer in play. I always release it and immediately hit the switch again to reactivate the limiter.
Barney
Barney
Post  Lem Evans May 25th 2012, 8:57 pm
So, is it in or after the 'box' ? We may never know Laughing But I suspect it's after.
Post  richter69 May 25th 2012, 9:18 pm
my burnout limiter is on a switch on the control panel, it also disables the data recorder for the 7531, EGT data logger and the record on the tach...............I've only forgotten to turn the switch back off twice............ Laughing
Post  schmitty May 25th 2012, 9:20 pm
Suspect So what we're saying here is that if you go too fast in the box, an explosion may happen? Sounds kinky. Laughing
Post  Larry Williams May 25th 2012, 9:20 pm
"Should the driver take all the load off the engine immediately by popping the transmission into neutral at the same time getting off the accelerator? "
never ever try putting a glide in neutral past the traps!!! all sorts of weird things can happen. On my first full power pass in many years I did just that. I ended up in the wrong lane fish tailing when it went back in low gear. Good thing I was racing a chevy and he was way back lol
as well its in the rule book as a no no.
Larry Williams
Larry Williams
Post  richter69 May 25th 2012, 9:25 pm
the neutraling past the stripe is another can of worms, Its a no no on a 3 speed but a glide with a pro style brake should have no issues...........
Post  Barney May 25th 2012, 11:18 pm
My line loc switch controls my burnout limiter, it's on a pinky switch on my shifter, I let off it to release the brake pressure then immediately go back down on it to use the limiter. It's how I've always done it, there's probly better ways, but I've always done it that way.
Barney
Barney
Post  cool40 May 26th 2012, 12:52 am
i have a 3-step but its never had a chip in it for a line lock.
Post  466cj May 26th 2012, 1:45 am
schmitty wrote: Suspect So what we're saying here is that if you go too fast in the box, an explosion may happen? Sounds kinky. Laughing
Yeah.... kinda... sorta...
466cj
Post  LivermoreDave May 26th 2012, 1:51 pm
richter69 wrote:the neutraling past the stripe is another can of worms, Its a no no on a 3 speed but a glide with a pro style brake should have no issues...........
..... nor should there be any issues with a well prepped 3 speed, installed properly!
Dave.
LivermoreDave
Post  fordman50 May 28th 2012, 9:04 pm
all that low end stuff is Chinese.. and works ok
fordman50
