moroso oil pump
moroso oil pump Empty moroso oil pump
Post  cooter May 28th 2012, 10:48 pm
just built a dart block 400 chev and used a moroso high volume pump, started motor and got 85-90psi at 2750rpm and 60 psi at idle. The pump came with a new spring which is suppost to drop the pressure 8-10psi so i installed it and the psi dropped to 55 at 2750 and 30 at idle. Do i assume the pump came with the wrong spring in the first place? Has anyone else had this happen?
cooter
moroso oil pump Empty Re: moroso oil pump
Post  rmcomprandy May 28th 2012, 11:35 pm
With a MOROSO Chevy pump ... usually the high volume pump comes with the high pressure spring installed with the regular spring separately and the standard volume pump comes with the regular pressure spring installed and the high pressure spring separately.
The pressures given in their instruction sheet are simply the averages of several different engine combinations and oil combinations.
Post  cooter May 28th 2012, 11:48 pm
thanx randy, it scared the hell out of me to see 90 psi.
cooter
