Moroso 63595 Water Pump
Does anyone know how far the Moroso 63595 pump sticks out from the timing cover?
BIGDOG466- Posts : 265
Re: Moroso 63595 Water Pump
Answered my own question but good info to know so I posted it. Found on Summit Website
Brand Moroso
Manufacturer's Part Number 63595
Part Type Water Pumps, Electrical
Product Line Moroso Billet Aluminum OEM Mount Electric Water Pumps
Summit Racing Part Number MOR-63595
UPC 84663635953
Pump Material Aluminum
Pump Finish Clear anodized
Flow Rate @ 12 Volts (gpm) 30-37 GPM
Hose Adapter Required Yes
Hose Adapter Included No
Inlet Hose Size (in) 1 in.
Overall Depth (in) 5.625 in.
Amp Draw 7.00 amps
Quantity Sold individually.
Brand Moroso
UPC 84663635953
Amp Draw 7.00 amps
One thing to note about these pumps is that compared to a CSR or a Mezeire, the water inlet is angled forward toward the radiator. The CSR and Mezeire have an inlet that is parallel with the front of the block. I tried to put a borrowed one on my engine and couldn't because of the angled inlet put my braided line at an odd angle, too close to the rad. and wouldn't line up.
BigDave65- Posts : 567
i have one.i had to mill the motor plate behind it for the rotor to clear but it works good.
Thanks for the suggestions.
» Switched from mech water pump to Moroso electric water pump
» Moroso water pump
» PARTS CLEAN OUT
» Who runs a Moroso/Mr Gasket water pump drive kit?
» Moroso water pump drive
» Moroso water pump
» PARTS CLEAN OUT
