solenoid
solenoid
are super power shot noids worth rebuilding for use with a controller. and what type of controller should be used with lower hp kit
quick 52- Posts : 612
Re: solenoid
IMO NO,
Steve Johnson has the larger selonoid for just a litle bit more than a rebuild kit and has teflon plungers. and if you are spinning 175hp or lower you need to look at suspension first.
studly- Posts : 512
Re: solenoid
i do spin with much less than 175hp being a truck with leafs and nose heavy im sure there is away to get it to hook but hoped a controller would be helpful it does 60 ok on motor but can't handle the hosestudly wrote:IMO NO,
Re: solenoid
a progressive will help,
studly- Posts : 512
Re: solenoid
Here's a link to a great solenoid that will also have a Teflon plunger in it as well as more orifice then most will ever need..
http://www.induction-solutions.com/shop/product_info.php?products_id=194
As for a controller, we use and sell the Edelbrock 71900 as well as the newr NMS-1000. Both do a great job and the Edelbrock is the least expensive and quickest and easiest to work with.. Thanks, SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
» Tci Trans solenoid only one left Make offer sold
» EDELBROCK RPM NITROUS SOLENOID
» Summer Solenoid Sale
» starter for 95 F350, solenoid + relay???
» C6 transbrake solenoid dripping fluid
