Another Pushrod chewed up
+8
powerstrokeace
LivermoreDave
crittersf1
quick 52
LETHAL_DOSE
12 posters
Page 2 of 2 Previous  1, 2
Another Pushrod chewed up - Page 2 Empty Re: Another Pushrod chewed up
Post  dfree383 September 10th 2012, 2:49 pm
Bushing leaking a lot of oil once it gets hot?
Can you get them remeasured?
What direction are they wearing from? To or away from the pressure feed?
Post  LETHAL_DOSE September 10th 2012, 3:25 pm
These bushings still measured good before it was put together this last time. They only have about 16 passes counting 12 dyno pulls on them. I am thinking about taking it to Phillip or Rich and let them look it over to see if they can straighten it out. I have already invested a small fortune in this thing, and I hate to keep throwing good money after bad. I am just low on funds at this time because I have invested so much into it. My plan is to probably take a year or two off and save up some more play money (I definately overspent my budget this year), and then take this to one of them and have them fix it.
LETHAL_DOSE
LETHAL_DOSE
Post  samiam September 10th 2012, 7:23 pm
I had a similiar problem, changed cam and lifters ,went to the ford A514 Cam an Lifters, had no oil pressure,, after tear down I compared the new lifters to my old pro comps and there was a difference in oil ring hole hieghts, went back to pro comps, 70 psi .....Block is a C8VE
I still have these lifters, will they wok in the a460 block
samiam
samiam
Post  Lem Evans September 10th 2012, 7:34 pm
I suspect it may be in here somewhere but what block do you have?
Post  LETHAL_DOSE September 10th 2012, 10:22 pm
It is an eliminator block, Premier.
LETHAL_DOSE
LETHAL_DOSE
Post  AlkyPinto September 11th 2012, 6:05 pm
I had kinda the same problem back in 06 with my SVO block.
The pushrods just werent getting enough oil and would
actually get this bad:
Another Pushrod chewed up - Page 2 Pushrod
After talking to a number of engine builders I heard stories of
some Mopar hemi engines having the same problem until they
grooved the roller lifter hole. The Crane roller lifters at that time
actually came grooved for BBFs. Kaase also provided them.
At the time I had Cam Motion roller lifters and Kaase told me
how to do it myself with a cutoff wheel.
RichAnother Pushrod chewed up - Page 2 Lifter
Once I did this my pushrod problems were gone forever!!! And I've
used grooved roller lifters ever since. IT WORKED FOR ME!
Rich
AlkyPinto
AlkyPinto
http://www.RichKentRacing.com
Post  richter69 September 11th 2012, 7:12 pm
After I got back from TN I was doing my regular maintenance and found the pushrod side of number 5 exhaust rocker black, upon inspection the pushrod was starting to gall up. This engine has had the green oil in it ever since broken in w vr1. I was out prior to the TN race and had to fix the oilpan from the previous outings bumper dragger so I had to put vr1 back in. After swapping the parts and oil I noticed all the the ex rockers were not oiling while it was running. Turning up the oil press did no good. I have the same lifters pictured above........ I ended up pulling the lifters out and slotting the holes like I have in the past. Alls good now.........I'll tell ya this all jokes aside about the green oil I feel it was a crutch to my oiling issues and won't run without it ever again..........
Post  LETHAL_DOSE September 11th 2012, 9:17 pm
That is the weird thin about i, I have grooved my lifter toget oil at all times during the valve sequence, and not just a little. It is a significant amount, and still galling them up quickly. I spoke with a gentleman about pushrods & jesel rockers, and he is telling me I teed h-13 tool steel tip pushrods when running the jesel rockers. Any thoughts on this? I currently run a Trend, 4130 pushrod. He said the jesel cups are h-13 tool steel so the pushrods should be as hard or harder.
Mike
LETHAL_DOSE
LETHAL_DOSE
