pushrod length
maxxoffroad
56Tbird
hillbillyerv
pushrod length Empty pushrod length
Post  hillbillyerv December 6th 2010, 11:23 pm
from what ive read factory pr are 8.550 so since my heads were shaved 10thous. should i go with a 8.540? plus i think my in. valves are .100 longer than stock??? ???? 8.450??? input will be greatly appreciated . Erv.
hillbillyerv
hillbillyerv
pushrod length Empty Re: pushrod length
Post  c.evans December 6th 2010, 11:29 pm
Best just to bite the bullet and buy a pair of cheap adjustable checking pushrods. Check it with them and then proceed to order the correct length.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  hillbillyerv December 6th 2010, 11:31 pm
ok thanks uncle Charlie, how`s the weather in ole Kentuck??? Cool
hillbillyerv
hillbillyerv
Post  56Tbird December 8th 2010, 5:25 am
COLD Erv...9 degrees when i got off work at 2:30am......I saw a couple of beagle hounds trying to jump start a rabbit affraid king king
56Tbird
56Tbird
Post  hillbillyerv December 9th 2010, 10:55 pm
lmfao,, good one Dan, been cold here 2 14 last night 12 the night before Evil or Very Mad
hillbillyerv
hillbillyerv
Post  maxxoffroad December 9th 2010, 11:31 pm
Just take a old push rod and cut out about 1/2" and pot a 1/4" or smaller short piece of all thread in it with 2 nuts. Adjust till the right length and measure.
maxxoffroad
maxxoffroad
http://www.lonestaraxle.com
Post  rmcomprandy December 10th 2010, 11:32 am
hillbillyerv wrote:lmfao,, good one Dan, been cold here 2 14 last night 12 the night before Evil or Very Mad
Must be some kind of effect due to Global Warming, LOL.
Post  138 December 10th 2010, 12:10 pm
this might be a stupid question but when they square a block and deck it do they go off the mains or the cam tunnel?
138
Post  c.evans December 10th 2010, 11:50 pm
138 wrote:this might be a stupid question but when they square a block and deck it do they go off the mains or the cam tunnel?
Mains.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  138 December 11th 2010, 12:14 am
thank you...again
138
pushrod length Empty Who Sells
Post  540-DRAY December 11th 2010, 6:03 pm
He Charlie Who Sells The Push Rod Checkers Thanks An advance
540-DRAY
540-DRAY
Post  hillbillyerv December 11th 2010, 7:05 pm
540-DRAY wrote:He Charlie Who Sells The Push Rod Checkers Thanks An advance
not sure if any vendors on here carry them or not, they will chime in if so if not you can get em at summit or jegs or evilbay, i just made my own like suggested in post above cheers , now i gotta find some one with 12 in caliper Sad
hillbillyerv
hillbillyerv
Post  c.evans December 12th 2010, 1:16 am
Most cam manufacturers sell adjustable checking pushrods. Also, many of the shaft mounted rocker arm companies such as W.W. Engineering, Jesel, and T&D sell checking pushrods. Furthermore as mentioned above, it is pretty easy to make up a set for yourself.
Most importantly,,,,,is the fact that you need a 12" dial caliper in order to measure that pushrod length with.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Filucky December 12th 2010, 12:12 pm
maxxoffroad wrote:Just take a old push rod and cut out about 1/2" and pot a 1/4" or smaller short piece of all thread in it with 2 nuts. Adjust till the right length and measure.
I've done this before and it worked great! And it only takes a few minutes to fab up. Smile
Filucky
Filucky
