Would like some expert input on pushrod length WITH PICS!!
Would like some expert input on pushrod length WITH PICS!! Empty Would like some expert input on pushrod length WITH PICS!!
Post  Mr. Horsepower March 11th 2013, 10:08 pm
I am setting up a 545 with A429 heads, Dove MFG. 1.73 rockers, and comp Hyd. flat tappet cam, 274/286 adv. .562/.565 lift. What I have done is bolt the head to the engine, asemble one cylinder with Factory pushrods, and lifters that I shimmed up to 0.040" to simulate proper lifter preload, then I tightened the rocker till it was solid against the lifter (should have been about 0.040", It was about 1/2 turn in after contact to the lifter plunger) I marked the valve stem with a sharpie and went for it, turned the engine over a few time and took pictures. Here they are. I would like to see what you guys think before I order any pushrods.
Would like some expert input on pushrod length WITH PICS!! 100_0601_zps10b8549c
Would like some expert input on pushrod length WITH PICS!! 100_0586_zpsdb855299
Would like some expert input on pushrod length WITH PICS!! 100_0587_zpsd67fdd5d
Would like some expert input on pushrod length WITH PICS!! 100_0588_zps99317fd0
Would like some expert input on pushrod length WITH PICS!! 100_0589_zps01f38352
Would like some expert input on pushrod length WITH PICS!! 100_0592_zps9c6cc6a2
Would like some expert input on pushrod length WITH PICS!! 100_0595_zpse4b650bb
Last edited by Mr. Horsepower on March 11th 2013, 10:39 pm; edited 1 time in total
Mr. Horsepower
Would like some expert input on pushrod length WITH PICS!! Empty Re: Would like some expert input on pushrod length WITH PICS!!
Post  whitefield March 11th 2013, 10:24 pm
Mr. Horsepower wrote:I am setting up a 545 with A429 heads, Dove MFG. 1.73 rockers, and comp Hyd. flat tappet cam, 274/286 adv. .562/.565 lift. What I have done is bolt the head to the engine, asemble one cylinder with Factory pushrods, and lifters that I shimmed up to 0.040" to simulate proper lifter preload, then I tightened the rocker till it was solid against the lifter (should have been about 0.040", It was about 1/2 turn in after contact to the lifter plunger) I marked the valve stem with a sharpie and went for it, turned the engine over a few time and took pictures. Here they are. I would like to see what you guys think before I order any pushrods. http://s1089.beta.photobucket.com/uhttp://s1089.beta.photobucket.com/user/RMWilliams2/media/100_0595_zpse4b650bb.jpg.html?sort=3&o=1ser/RMWilliams2/media/100_0601_zps10b8549c.jpg.html?sort=3&o=0http://s1089.beta.photobucket.com/user/RMWilliams2/media/100_0592_zps9c6cc6a2.jpg.html?sort=3http://s1089.beta.photobucket.com/user/RMWilliams2/media/100_0589_zps01f38352.jpg.html?sort=3&o=3&o=2http://s1089.beta.photobucket.com/user/RMWilliams2/media/100_0588_zps99317fd0.jpg.html?sort=3&o=4http://s1089.beta.photobucket.com/user/RMWilliams2/media/100_0586_zpsdb855299.jpg.html?sort=3&o=6http://s1089.beta.photobucket.com/user/RMWilliams2/media/100_0585_zps7be38142.jpg.html?sort=3&o=7
Can't open the link
whitefield
whitefield
Post  Mr. Horsepower March 11th 2013, 10:41 pm
Try it now, I worked on it and it worked now, but yeah, it didn't like the first one. thanks.
Mr. Horsepower
Post  bruno March 12th 2013, 7:30 am
Mr. Horsepower wrote:Try it now, I worked on it and it worked now, but yeah, it didn't like the first one. thanks.
fixed it for you Wink
http://WWW.CKRME.COM
Post  rmcomprandy March 12th 2013, 10:09 am
Just from the photos ... I would say that is not correct and it can't to the point of being correct with that selection of parts.
The spring and retainer look to be too close to the bottom of the rocker arm and it also appears to need a slightly shorter pushrod which can't happen because the rocker goes even closer to the spring/retainer.
If the engine has a solid flat tappet or solid roller lifter then a simple lash cap may solve the problems; can't use lash caps with a hydraulic lifter engine.
Changing retainers and accompanying springs would be necessary or using -.050" locks somehow.
Post  Mr. Horsepower March 12th 2013, 8:57 pm
thanks randy. I had no idea. I bought this stuff as a package deal. It might be better to buy some rockers that are right instead?? I was ready to assemble but if that is a serious issue, I will have to go another direction.
Mr. Horsepower
Post  Mr. Horsepower March 12th 2013, 9:16 pm
Thanks to bruno as well. Is there anything I can do from here other than start over? What do you typically look for for clearances between the valve spring retainer and the rocker? Can I check this and verify it?
Mr. Horsepower
