Which Water Neck for A460 Intake Manifold
Which Water Neck for A460 Intake Manifold Empty Which Water Neck for A460 Intake Manifold
Post  96Mustang460cid June 12th 2012, 9:55 pm
I have a Ford Motorsports intake for A460 cylinder heads. It is a single plenum (not tunnel ram) and has part # M-9424-A460. I thought these intakes used a SBF water neck. When I bought one, I quickly realized the bolt spacing was different. After doing some internet searching, I realized that some intakes have the water neck flange positioned vertically while other, like mine, are positioned horizontally. Before buying another $100 water neck, I'd like be sure I'm buying the right application.
Do these intakes use a BBF water neck? If I had one laying around, I'd try it out...but I don't Smile.
Have a good day!
Michael
96Mustang460cid
96Mustang460cid
Which Water Neck for A460 Intake Manifold Empty Re: Which Water Neck for A460 Intake Manifold
Post  David Cole June 12th 2012, 10:22 pm
The Ford A460 intakes use a regular bbf thermostat housing/water neck.
The new style TFS intakes use a sbf housing/water neck.
Post  curleysracecars June 13th 2012, 1:05 pm
If you need something custom, let me know. I started a thread about this the other day...let me know if I can help.
https://www.429-460.com/t14381-are-custom-water-necks-needed-for-bbf-s
curleysracecars
curleysracecars
http://www.curleysracecars.com
