16an water neck for bbf
BigDave65
bigjohn2007
i'm trying to put braided line for rad. but can't find anyone who makes one for the bbf.anyone who has run braided line to their rad. please chime in.
bigjohn2007- BBF CONTRIBUTOR
Re: 16an water neck for bbf
Here is one:
http://www.summitracing.com/parts/CSI-9112AN16B/
Meziere makes one with interchangeable screw in AN fittings.
Or make you own with a flat plate cut to size and a weld in -16 bung. Just need access to someone who can TIG aluminum.
I machined my own from a block of aluminum and just screwed a straight adapter into it. The adapter points in the same direction as a stock waterneck and uses a straight hose end. I have seen the where the adapter points straight up and they use a 90 degree hose end.
BigDave65- Posts : 567
I have a -16 for a smallblock, plus a bunch of hose and some fittings...........
Wheelie58 wrote:I can make you one....
Keith
678-458-2033
At the risk of being accused of being an ass kisser, Keiths' work is top shelf all the way! It will be right when you receive it if you choose to go that way.
Nevs- BBF CONTRIBUTOR
I don't see how that makes one an azz kisser. If someone does a fabulous job on a part that one needs and then he tells his buddy, I would call that a well satisfied consumer.
schmitty- Posts : 4538
schmitty wrote:I don't see how that makes one an azz kisser. If someone does a fabulous job on a part that one needs and then he tells his buddy, I would call that a well satisfied consumer.
I know Rob, but you know my past history.........
I used the Meziere unit that David spoke of with -20 fitting. At the time that was the only thing available that had AN fittings for it. Also I didn't know that TFS used the SBF pattern on their A460 manifolds. Never have understood that move ! So to use what I had I made this adapter on my band-saw and drill press. Works great, here's a couple of old photos.
Thanks!
Nevs wrote:Wheelie58 wrote:I can make you one....
Keith
678-458-2033
Thanks!
Keith
What your price Keith and how you take payment?
Water outlet
John,
Just give me a call and we can discuss exactly what you need.
I will have to custom make the part, but will price it as fair as possible.
The outlet that I have on my TFS tunnel ram is pretty simple. It is a flat plate with a male AN fitting welded to it.
I am looking for a picture of it now.............
And for the type of payment....checks are fine.
Thank you,
Keith
678-458-2033
Thank you,
Keith
678-458-2033
i have victor 460 intakeWheelie58 wrote:John,
Thank you,
Keith
678-458-2033
» A460 trickflow intake water neck
» water neck
» 16AN or 20AN Radiator fittings
» Water neck
» Which Water Neck for A460 Intake Manifold
» water neck
» Water neck
