Water neck
Water neck Empty Water neck
Post  bbf-falcon September 9th 2009, 12:29 pm
Guy's when had the engine in Tweety ,I was expieriencing some trapped air in cooling system problems. My problem is my rad. and filler tube is lower than my thermostat housing. I'm looking for a extended waterfill that mounts on the front of my A460 intake (SBF style) and extend up about 4 to 5" w/filler cap on top a
and has a AN16 fitting coming off the side for the rad. hose. Someone told me the Dragsters used them Exclamation
Anyone, anyone Laughing
Water neck Empty Re: Water neck
Post  the Coug September 9th 2009, 12:43 pm
Rick go over to the EMC engine post and look on page 4 and see the water pump that bruno found for that problem...
Post  Doug Rahn September 9th 2009, 6:11 pm
Are yo talking about something like this. This is what David Cole has on his pipe rack. The manifold adapter is made by a guy who calls himself Cobra Earl, it converts the SB Ford to Chevy. I have one I'm going to use on the SB Mustang, nice piece.
Water neck Bullet3
Post  the Coug September 9th 2009, 6:15 pm
Post  c.evans September 9th 2009, 6:28 pm
Rick,
I think what you'll need, is like what David Cole is running on his dragster. Contact him. IF, the engine still airlocks, then we/you can install a couple of bleeder valves in the back of the intake manifold, directly above where the water opening is from the intake surface of the heads. I had Todd Lawyer install a bleeder valve on Krissy's dragster.
What Doug has pictured there is very similiar to what we've made (homemade) in years past.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Doug Rahn September 9th 2009, 6:31 pm
Here's a better photo of the adapter.
Water neck 225759610qguhcs_phaa.jpg.w300h225
Post  bbf-falcon September 9th 2009, 8:10 pm
Great idea's Guy's,Thanks for the reply's. Got some good leads today.
Post  David Cole September 10th 2009, 1:14 am
I use the Cobra Earl adapter as Doug and Charlie mentioned. I use it with a CSR extended filler neck for a bbc. They have the filler neck with the -16 you need in either 3" or 6" tall. There are several other brands of similar product out there. Dedenbear has a good one.
The CSR part:
http://www.jegs.com/i/CSR/170/99134/10002/-1
The Cobra Earl adapter that Doug posted the pic of:
http://www.cobraearl.com/products/
Post  bbf-falcon September 10th 2009, 3:42 am
Thanks David, Thats a Sueeeeet piece. Laughing
