valve adjustment sequence on my 520ci motor
speedracer
i need to find out what valves you adjust when the engines at top dead center, & when you rotate the motor back up to top dead center when the #6 piston is firing? i know this is the old way of doing it but ive been doing this by using the balancer for a long time now and thats the only way i know how. i just forgot the sequence of the valves, & lost the paper i had the info on. could use your help. thanks!
speedracer- Posts : 5
Re: valve adjustment sequence on my 520ci motor
EOIC........
dont understand what you mean.richter69 wrote:EOIC........
on any 4stroke engine.... EO means (Exhaust Open) adjust the intake vale just as the Exhaust valve.. Opens., and IC, means (Intake Closing) adjust the Exhaust valve after u watch the intake go all the way down and just start back up ( starting to Close, in other words )........... this works on 3hp briggs and stratton all the way to Top Fuel
jc10000rpm- Posts : 193
When the exhuast valve opens and the intake valve just starts to close that is when you set the lash on the exhuast valve and then the same on the intake valve, when the intake valve opens and the exhuast valve just starts to close that is when you set the intake valve lash. I am sure someone will chime in if I am steering you wrong.
Good luck
Dave
Good luck
Dave
NO FAIR- Posts : 138
thanks for the info. believe it or not, i have never adjusted the valves this way because i do not now how. never tried. im used to doing it off the dampner. can you help? thanks...jc10000rpm wrote:on any 4stroke engine.... EO means (Exhaust Open) adjust the intake vale just as the Exhaust valve.. Opens., and IC, means (Intake Closing) adjust the Exhaust valve after u watch the intake go all the way down and just start back up ( starting to Close, in other words )........... this works on 3hp briggs and stratton all the way to Top Fuel
dave, your not wrong. i just never adjusted them that way. ive done them by using the dampner. im sure someone knows out there. thanks for responding.NO FAIR wrote:When the exhuast valve opens and the intake valve just starts to close that is when you set the lash on the exhuast valve and then the same on the intake valve, when the intake valve opens and the exhuast valve just starts to close that is when you set the intake valve lash. I am sure someone will chime in if I am steering you wrong. Good luck
Dave
with a big roller this is about the only way,IMO.richter69 wrote:EOIC........
when using the balancer, follow the firing order and adjust the intake and exhaust valves . Start with #1 at top dead center on the power stroke ( after the intake valve closes). turn the crank 90 degrees at a time
cooter- Posts : 220
» valve adjustment
» Valve adjustment order
» Valve Adjustment Help...I think I messed up
» Aftermarket valve adjustment
» Hyd lifter valve lash adjustment
