chevy question
chevy question
have a 502 gen 5 i built in a jetboat. after 13 hours of 4600 rpm all was well until the next boat ride. after 5 minutes it pushed out the one piece rear seal. Any idea why?
cooter- Posts : 220
Re: chevy question
DanH wrote:it a chevy , to much blowby
YES ... for some reason the blow-by increased enough to blow out the seal.
Re: chevy question
wouldnt blow by push out the dipstick instead of the seal?
cooter- Posts : 220
Re: chevy question
whats the oil pressure?
Re: chevy question
60 at 4600, 20/50 amsoil
cooter- Posts : 220
Re: chevy question
is the seal installed correctly?
Stock or aftermarket crank?
Re: chevy question
as it turns out, the seal was not installed far enough into the bore, i installed it flush like a smallblock chev 1 piece seal. I also used silicone instead of installing it dry. Live and learn i guess.
cooter- Posts : 220
Re: chevy question
you'll know next time ! Lesson Learned
Re: chevy question
cooter wrote:as it turns out, the seal was not installed far enough into the bore, i installed it flush like a smallblock chev 1 piece seal. I also used silicone instead of installing it dry. Live and learn i guess.
Using silicone ... if it doesn't sit for a week, it will come out again.
Re: chevy question
thanx randy, wont use silicone this time. How tough is it to get a new seal in without removing the main cap?
cooter- Posts : 220
Re: chevy question
not sure if one is made for your engine, but i have a tool to install one piece seals on sbc motors. kent-moore. looks like a cone shaped hub with a large wing nut. it threads into the back of the crank and tightening the wing nut pushes the seal in.....bobn
zbob- Posts : 271
Re: chevy question
i thought i would pull the pan, check bearings and install the seal with the main cap off. Killed two birds with one stone. bearings look like new and the seal slid right in. thanx for the help.
cooter- Posts : 220
» Chevy repair question.
» Chevy Help
» EMC is run by chevy huh?
» help with a pos chevy
» Chevy Help
