Fuel pump complete setup prefer with filter support 700-800 hp carb
magnafuel ,weldon ect
5pointslow- Posts : 1408
fordguy- Posts : 11
pump?
have a barry grant 280 with bult in regulator so you dont need an extra return line...was asking 175. do 150. was working fine maintaining 8 psi on 532 bbf jet boat.
bbfdragster- Posts : 121
Re: Fuel pump complete setup prefer with filter support 700-800 hp carb
im curious ? no return built in regulator ...so run no reg by the carb either ??
pump
No...still need regulator for Carb.. I put in a Barry grant 400 and u need a return line back to take to return extra fuel... 280 pump doesn't need extra return line...adjusts inside wit a spring style relief valve...easier to hook up.
I have a product engineering pump/filter combo, and also a regulator to go with it. It is a PE4450 pump and the regulator I have is a PE9400.
I will take $400 plus shipping for both pump and regulator. If you want a belt drive set-up, I have a Bo-Laws with internal by-pass that I used to use on a 750hp alky engine, $250.00 for it.
pm me if you are interested
LETHAL_DOSE- Posts : 62
LETHAL_DOSE wrote:I have a product engineering pump/filter combo, and also a regulator to go with it. It is a PE4450 pump and the regulator I have is a PE9400.
I'm curious,does this pump need a return line from the reg. also,besides the return from the pump to the tank?
Not with this regulator, it is a deadhead style. I only used this pump for about 3-4 passes. I went back to my belt drive set-up. Nothing wrong with it, I just like my belt drive pump better. I bought the whole pump set-up; lines, fittings and everything from Chuck Nuytten about 4-5 years ago.
That is one of the BEST pumps on the market that you have. Thx
» Filter setup for dominator carb , suggestions
» WTT: complete Enderle Mechanical Injection for dual carb setup
» fuel pump filter.
» Fuel pump,Regulator and Filter SOLD
» Transmisson core complete c-6 & holley fuel pump
» fuel pump filter.
