fuel pump filter.
fuel pump filter. Empty fuel pump filter.
Post  FORDMUD March 15th 2012, 10:19 pm
I have an A2000 pump with a 74 micron prefilter and a 10 micron outlet filter. How close can the outlet filter be to the pump? I'm intending to use a -10 swivel coupler. The filter is a decent sized Canton unit. I'm also using the pump bypass returning to the tank.
FORDMUD
FORDMUD
fuel pump filter. Empty Re: fuel pump filter.
Post  GTmustang March 20th 2012, 7:53 am
The Aeromotive kit for fox bodies tells you to mount the inlet and outlet filters directly on each side of the pump, so I guess it doesn't matter. Mounting the outlet filter closer to the carb will protect the carb better from possible trash coming from a fuel line that might start to deteriorate on the inside.
Gary
GTmustang
Post  FORDMUD March 20th 2012, 11:26 am
fuel pump filter. 28lb62g
I'm going to run it like this. I do like the idea of the filter closer to the carb though.
FORDMUD
FORDMUD
