7's with iron heads & N20
+6
466cj
Barney
STR-LGL-70
10 posters
7's with iron heads & N20 Empty 7's with iron heads & N20
Post  STR-LGL-70 June 23rd 2012, 2:02 pm
I realize this is a wide open question with a lot of variables so don't be too hard on me.
Some specifics:
572" alum rods,bryant crank, venolia F.T. blower/N20 pistons. Either aftermarket or Dove-A block that I already have.
Ported iron scj heads w/injector on t ram, methanol, C-6 trans.
Car is 3000# w/driver 2x3 chassis and still has all glass, steel body except hood so it can be lightened somewhat.
I know with different heads, etc it would be no problem; would really like to try it with factory iron.
Fire away!! Very Happy
Sheldon G.
STR-LGL-70
STR-LGL-70
7's with iron heads & N20 Empty Re: 7's with iron heads & N20
Post  BOSS 429 June 23rd 2012, 9:10 pm
well we've been 8.50s with dove heads and a small kit,and a lot smaller engine,and im sure the guy I built the engine for will give it a try also when he gets time
yes it can be done
Post  richter69 June 23rd 2012, 11:06 pm
Here we go.......... Wink Very Happy
Post  dfree383 June 24th 2012, 12:28 am
Get rid of the meth if your want to go fast...... cheers
And put it on a big time diet !!!
Post  Barney June 24th 2012, 1:58 am
richter69 wrote:Here we go.......... Wink Very Happy
I hope so.... Not at US 43 with the heat that blew in this weekend. Razz
Barney
Barney
Post  466cj June 24th 2012, 3:25 am
There have been N/A D0OE-R engines build with less cubes than yours that have come close to an honest 900 hp. Add in a 300 - 400 shot and provided your car is well sorted a high 7 don't see why not.
466cj
Post  BOSS 429 June 27th 2012, 11:12 am
STR-LGL-70 wrote:I realize this is a wide open question with a lot of variables so don't be too hard on me.
Some specifics:
Sheldon G.
the point is tho is it really worth it to do it? but with enought time and $$$ sure it can be done
Post  ifucan July 6th 2012, 9:53 pm
BOSS 429 wrote:well we've been 8.50s with dove heads
whose head work?
ifucan
Post  richter69 July 6th 2012, 10:15 pm
I dont think these heads were dug out of a salvage yard and whittled on a bit with a die grinder lol.
Post  Barney July 6th 2012, 10:58 pm
whose head work?
circle R we've had 2 in the 8s on a single plate at 3000 lbs. the question is how much can you do yourself ? If you had to pay someone to do the work, I'm not sure how cost effective it would be given the volume of aftermarket castings out there. Unless there are rules dictating iron heads it's probly better to go the aftermarket arena.
Barney
Barney
Post  BOSS 429 July 7th 2012, 10:40 am
whose head work?
Mine, ive done about 8 pair like this its a lot of work, 1 guy just wanted steel oem heads, 3 pair were for truck pullers
Post  BOSS 429 July 7th 2012, 10:42 am
richter69 wrote:I dont think these heads were dug out of a salvage yard and whittled on a bit with a die grinder lol.
your right, lot of welding ,grinding,more welding,and grinding again,lol
Post  rmcomprandy July 7th 2012, 11:11 am
ifucan wrote:
whose head work?
As has been said, it is certainly possible but, at how much effort to keep the iron SCJ heads...?
Lane Carey has probably the most "worked over" pair of iron SCJ's on the planet and I'd venture to say there is $10,000 in those heads however, his rules in FAST dictate that is what NEEDS to be done.
It is your decision as to how far you are willing to go in order to simply keep factory iron.
Post  ifucan July 8th 2012, 2:05 pm
Yeah, Lane and I share the same builder
ifucan
Post  ifucan July 8th 2012, 2:07 pm
Barney wrote: Unless there are rules dictating iron heads it's probly better to go the aftermarket arena.
unless you are a grudge racer
ifucan
Post  richter69 July 8th 2012, 4:57 pm
just buy the whole engine, its for sale................ http://www.460ford.com/forum/showthread.php?t=159749
Post  Barney July 8th 2012, 7:25 pm
Shhhhhhh...
Barney
Barney
Post  ifucan July 8th 2012, 7:30 pm
Shhhhhhh...
"ssshhhhhh, be very, very quiet...we are hunting rabbits"- Elmer Fudd
ifucan
7's with iron heads & N20 Empty Why?
Post  mkopmani July 14th 2012, 7:09 pm
A $3500 Bryant crank, $1200 Venolia pistons, $1200 aluminum rods with $80 heads and a $100 block = Mismatch. Why???
Seems that you could go a lot faster if you matched things up.
mkopmani
Post  yellowhorse7 July 15th 2012, 12:10 am
mkopmani wrote:A $3500 Bryant crank, $1200 Venolia pistons, $1200 aluminum rods with $80 heads and a $100 block = Mismatch. Why???
If you are referring to me.....I don't have any of those things
yellowhorse7
yellowhorse7
Post  466cj July 15th 2012, 1:04 am
He is refering to the OP. Is all in the first post.
466cj
Post  STR-LGL-70 July 22nd 2012, 8:53 pm
Heads were $ 75.00 Cool
STR-LGL-70
STR-LGL-70
