1989 drag radial coupe
89 mustang full cage
557 kaase engine
a460 block
kaase P51 heads
eagle rotating assembly
14.5 diamond nos pistons
csr water pump
victor intake ported to match heads
1250 ultra dominator
j&w power glide trans
bte plant.
stallion nitrous converter
pro brake
8.8 rear end with aftermarket tubes
3.55 gears\
moser 35 spline axels
bte housing
wyles driveshaft and aftermarket yolks
champion wheels
front 15-4.5
rear 15-12 double bead lock
msd powergrid ignition
msd HV2 coil
nitrx progressive system
induction solutions fogger
3 10lb bottles
this car has too much to list i would be typing all day, its a beautiful car and drives great, this car is street legal , would make someone
a great car. this car is all new setup has only 10 test passes on it, selling due to bussiness is too busy and just dont have time for it....
$$25,000.00 obo
557 kaase engine
a460 block
kaase P51 heads
csr water pump
bte plant.
pro brake
3.55 gears\
bte housing
champion wheels
front 15-4.5
msd HV2 coil
3 10lb bottles
$$25,000.00 obo
Last edited by michealj on June 24th 2012, 12:51 pm; edited 1 time in total (Reason for editing : wrong loctatio)
michealj- Posts : 78
Re: 1989 drag radial coupe
#####reduced $22,500.00obo.[b]
» cant get any damn info , ive put on yellow bullet ect ... the diff between a drag radial,radial slick,bias slick pros and cons
» 1989 Ford Mustang 521 BBF Coupe
» New M/T drag radial.....295/55/15
» 1st drag radial test
» 89 drag radial mustang
