cant get any damn info , ive put on yellow bullet ect ... the diff between a drag radial,radial slick,bias slick pros and cons
i heard radial slicks like the hoosiers not dot radials ...hook and are stable ect .....but i want a good pros and cons about all 3 hopping some good knowledge steps up
5pointslow- Posts : 1408
Re: cant get any damn info , ive put on yellow bullet ect ... the diff between a drag radial,radial slick,bias slick pros and cons
your best bet would be to call the folks that make them for info.not many run the "radial"slicks.
The m/t section on the 'bullet is pretty slow traffic, a radial will be faster but way less forgiving if everything including the track is not just right.
i was thinking about trying a set of 30 x 10.5 hossier radial slicks .......i did here from somone that radial slicks are stable and if they hook they bite real hard
whats the combo and intended use?
9.50 index class
IMO put a reg slick on it, stiffwall if the car is heavy and has a lot of power.................The radial I think you are refering to is like what the super stock guys run.
» E85 Pros and cons ?
» Pros and Cons
» Yellow Bullet
» Crank stroke 4.3 or 4.5? Pros/Cons
» Pros and cons on 6.0 , 6.7 ford diesels
» Pros and Cons
» Yellow Bullet
