Pros and Cons
jason
ironbark
Pros and Cons Empty Pros and Cons
Post  ironbark March 23rd 2014, 6:54 pm
Can anyone pass on the Pro's and Con's of running a race motor only with or with out water. it is on metho.
ironbark
Pros and Cons Empty Re: Pros and Cons
Post  jason March 23rd 2014, 7:32 pm
From what I've been told, if it's gonna be pulled to the starting line and back to the pits you don't need to run water.
jason
jason
Post  supervel45 March 23rd 2014, 7:38 pm
When you fill the block with block fill it is alot stiffer and the cylinder walls can take more abuse. Don't need much cooling to go a quarter mile on a cold start. Loose alot of weight from the vechicle also, and if you run a magnito, you don't need a battery either.
Post  maverick March 23rd 2014, 8:11 pm
You're gonna need to crank it, however...
Post  supervel45 March 23rd 2014, 8:15 pm
Jumper cables or push start, LoL
Post  ironbark March 23rd 2014, 8:18 pm
yes it is a tow up and back, thanks for the input.
ironbark
Post  dfree383 March 23rd 2014, 10:27 pm
I'd at least hot block it if it's not a filled or solid block.
Post  richter69 March 23rd 2014, 11:27 pm
run it through the block and heads, no need for a radiator just use a small tank to keep the air out of the system.
block heaters are your friend, ps they wont work unless they have water to heat up......
Post  bbf-falcon March 24th 2014, 8:56 am
My engines always perform better at 160*+ from the starting line.I feel safer engine wise w/the water being circulated evenly thoroughout the engine. No theory behind it,just me. Smile
Post  DanH March 24th 2014, 12:00 pm
bbf-falcon wrote:My engines always perform better at 160*+ from the starting line.I feel safer engine wise w/the water being circulated evenly thoroughly the engine. No theory behind it,just me. Smile
best thing said about cooling Rick- it works for you
DanH
