Piston Out of the Hole - Pros/Cons
What are the pros/cons of the piston being .050 out of the hole requiring a gasket of ~.100? Will the Cosmetic MLS gasket hold with 14.5 Compression and an occasional 150 HP shot? This is a drag racing application, 4.560 bore, using A460 heads.
Thanks,
Thanks,
tompietwo- Posts : 43
Re: Piston Out of the Hole - Pros/Cons
I've run um out of the hole 0.020 or so, but this was to clean up a deck that was torched between two cyls one time. I used a .065 or so Cometic gasket and it worked fine. That said .050 is a quite a bit, I wouldn't do it if i had to lol.
Not the best situation but i'll work if you don't get greedy with spray.........it puts the top ring too close to the deck for a lot of extra heat.
Thanks Lem,
I that case, think I'll stick with the shorter (6.7) rods.
tompietwo wrote:Thanks Lem,
That would be a good idea imo
» Pros and Cons
» E85 Pros and cons ?
» Cheap 460 thrasher build plan for bracket tbird
» Need some advise on a Port O Sonic single plane intake . Pros & Cons !
» Pros and cons for low tension oil rings
