exhaust valves
exhaust valves
What situations can cause the transfer of aluminum to the exhaust valve face? its on all 8 exhaust valves
Larry Williams- Posts : 884
Re: exhaust valves
Lean or low timing.
Re: exhaust valves
Generally a very lean condition, especially when one is spraying nitrous. The aluminum comes from either the piston tops, or from the chambers. If you clean the chambers carefully you may see some porosity holes in the casting that weren't there before. They tend to be more commonly found in the cuspid between the two valve seats. That same lean condition also tends to blow head gaskets.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Re: exhaust valves
timing was at 32 degrees it was very lean at least looking at the plugs
» TFS 290 and 325 heads exhaust valves
» Brand new Manley 2.190 intake and 1.76 exhaust valves
» the dove c heads i bought , i measured the intake valves they were 2.250 assuming these are not stock valves ?
» Valves
» Titanium valves: 2.25 valves SOLD; 2.35 valves SOLD,2.40 valves SOLD
» Valves
