Super Cobra Jet Heads
njstang87
Super Cobra Jet Heads Empty Super Cobra Jet Heads
Post  njstang87 July 8th 2012, 2:51 pm
I have the opportunity to pick up a set of Aluminum SCJ heads. They have Ferrea valves 2.250/1.860 and he thinks they are titanium. They come complete with 1.73 scorpion rockers and jomar stud girdles. They have been ported a little. They flow 345 intake and 245 exhaust. He said they were also cleaned up around the combustion chambers.
He only ran these for a summer just on the weekends with no trips to the drag strip.
First question is what is a fair price for this hardware?
Second I believe my pistons are flat tops. So I know I would have to have reliefs cut into them. I looked at the reincarnation website and it says compression of 11 to 1. I want this to be a pump gas motor. So will this be acheivable or not?
Thank you
njstang87
Super Cobra Jet Heads Empty Re: Super Cobra Jet Heads
Post  Lem Evans July 8th 2012, 2:57 pm
Are you sure it's not a 1.76" ehx. valve?
Post  njstang87 July 8th 2012, 2:59 pm
Not sure Lem. This is all from his memory. I thought that sounded off...
njstang87
Post  rmcomprandy July 8th 2012, 3:35 pm
If they are Ferrea valves a 1.800" is possible for the exhausts.
As for worth ... less than the price of new ones.
Post  c.evans July 8th 2012, 7:07 pm
I'd run away from that deal, fast! "He thinks they are titanium" is just a sales pitch. They either are or they aren't. If the valves were new titanium valves, then they alone cost $2,000 for a set of 16. So, ignore that part about titanium valves. Also, you better measure the valve diameters accurately with dial calipers before you even think about paying any money. SCJ heads come from the factory with 2.200" valves, not 2.250".
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  schmitty July 8th 2012, 11:22 pm
Does Ferrea even make a Ti valve?
Post  c.evans July 8th 2012, 11:26 pm
Yes they do.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  njstang87 July 9th 2012, 11:45 am
Thanks guys. So 1500 isn't a deal for all of these parts?
njstang87
Post  nuclearcobra July 9th 2012, 12:19 pm
sure its a heck of a deal if there not hurt at all ,but beware like charlie already said Shocked
nuclearcobra
nuclearcobra
Post  c.evans July 9th 2012, 1:30 pm
Yes, $1500 is a good deal for those heads with stainless steel valves, but you never said how much in the beginning. For $1500 they sure as heck aren't titanium valves. Also, unless he can give you a flow sheet with the porters name and etc.,,,,I wouldn't put too much faith in those flow numbers.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  njstang87 July 9th 2012, 1:40 pm
Thanks Charlie. He does have the flow sheet. Steve Schmidt Racing here in Indy did them.
njstang87
