tfs A460 vs kaase super cobra jet
+9
mikey hefner
yellowhorse7
dirt_worker
psfracer
v-twin
13 posters
tfs A460 vs kaase super cobra jet Empty tfs A460 vs kaase super cobra jet
Post  v-twin October 14th 2013, 2:38 am
what would be the hp difference ,I have super cobra jet kaase heads on a 521. I need to change my cam and piston anyway I go because the ones in my motor are low compression 9.6..I think 14.5 compression more cam ,new 100 longer valves so I can go up on cam lift, Should net 100 more hp , current cam is comp 726 lift 268 276 dur. Or go with tfs A head......Car runs 8.93 - 152 1/4 5.78 122 1.8 at bristol 400 shot
v-twin
v-twin
tfs A460 vs kaase super cobra jet Empty Re: tfs A460 vs kaase super cobra jet
Post  dfree383 October 14th 2013, 2:43 am
on equal engine's the A460 stuff will make 100 more HP +/-, The boss stuff is similar.
Post  rmcomprandy October 14th 2013, 10:06 am
v-twin wrote:what would be the hp difference ,I have super cobra jet kaase heads on a 521. I need to change my cam and piston anyway I go because the ones in my motor are low compression 9.6..I think 14.5 compression more cam ,new 100 longer valves so I can go up on cam lift, Should net 100 more hp , current cam is comp 726 lift 268 276 dur. Or go with tfs A head......Car runs 8.93 - 152 1/4    5.78 122 1.8 at bristol   400 shot
That engine size is right at the point where ported SCJ's run out and the A460 heads come on so, more RPM is needed to make more power and a lighter valve train, (at least on the intake side), may be necessary with the A460's ... done right, they will make considerably more horsepower with about the same torque.
Post  v-twin October 15th 2013, 2:04 pm
thanks for the info So my scj kaase heads are about done? I'm running 9.90's at Bristol which would be 8.60's anywhere else, Not counting Denver. I need 4 more tenth's. How much would compression help? I have 9.6 now
v-twin
v-twin
Post  dfree383 October 15th 2013, 2:51 pm
It will definitely help.
Whats the rest of the combo?
Post  v-twin October 15th 2013, 3:05 pm
521 ci diamond -36cc pistons, scat 4.300 stroker from aw brown. comp cam 726 lift 268 276 108 center 108 lobe Kaase cobra jet smoothed out and gasket ported, tci c6 4500 converter by ultimate, NX plate. For sale make offer
v-twin
v-twin
Post  dfree383 October 15th 2013, 3:07 pm
Get it up to 13-14:1 and get a proper no2 cam it will be worth a bunch of power.
Post  psfracer October 15th 2013, 3:34 pm
v-twin wrote:thanks for the info   So my scj kaase heads are about done? I'm running 9.90's at Bristol which would be 8.60's anywhere else, Not counting Denver. I need 4 more tenth's. How much would compression help? I have 9.6 now
What makes that track so bad?  1.3 seconds?  Really?  EDIT--oh nevermind, I see in other posts your running 8.90s.
v-twin wrote: 521 ci diamond -36cc pistons, scat 4.300 stroker from aw brown.  comp cam 726 lift 268 276   108 center 108 lobe Kaase cobra jet smoothed out and gasket ported, tci c6 4500 converter by ultimate,  NX plate.    For sale make offer
-3.6cc maybe?   I think like already said you bump up the compression to at least 13 to 1, go with a more aggressive cam, that will get you the 4/10ths I would think. But, if its in the budget, and you are changing pistons anyway, might as well step up to an A460 head. I had a buddy of mine build a very similar motor to what I did, but he used an A460 head and I used the P51. I have more compression, (16:1 vs 14:1) but he has more cubes (572 vs 598) but he made about 80 more horsepower.
psfracer
psfracer
http://www.psfracer.com
Post  richter69 October 15th 2013, 3:44 pm
P 51's are junk...............Razz
Post  psfracer October 15th 2013, 3:47 pm
I know. Cool
psfracer
psfracer
Post  v-twin October 15th 2013, 4:13 pm
Correction 9.90's on motor 8.90's NX nos 1.278 sixty 5.71 122 1/8 the air is bad here " 3900" my 521 was intended for a 1953 for f-100 street only. No p51 are not junk, he is full of his self . Ben reading about your car for 2 years now, great car.
v-twin
v-twin
Post  dirt_worker October 15th 2013, 4:14 pm
Lots of factors goin on here but after having p51s and now aheads I think the answer is clear. Just make the jump to aheads now....I guarantee you won't regret it.
I wish id just bought them to begin w actually....(so will fabio when he finally sees the light)
dirt_worker
dirt_worker
Post  v-twin October 15th 2013, 4:22 pm
Talked to Oakley today, Going Ahead for sure. So all my 521 stuff for sale
v-twin
v-twin
Post  IDT-572 October 15th 2013, 5:04 pm
A heads..............Twisted Evil
Post  yellowhorse7 October 15th 2013, 6:04 pm
richter69 wrote:P 51's are junk...............Razz
Got that right
yellowhorse7
yellowhorse7
tfs A460 vs kaase super cobra jet Empty learning
Post  mikey hefner October 15th 2013, 8:45 pm
I'm still learning, so which TFS A heads are you guys refering too?
mikey hefner
Post  v-twin October 15th 2013, 9:13 pm
I'm thinking new A360 which needs 4.600 bore so stock block should no go that big.
v-twin
v-twin
Post  v-twin October 15th 2013, 9:55 pm
what's not junk? trick flow has problems to, do you want to talk about rocker studs breaking the head? Drop the compression to 9.6 with small bore and use pump gas and see which is junk
v-twin
v-twin
Post  windsor October 15th 2013, 11:04 pm
It's an inside joke. The guy that said they're junk runs them and likes them. He was being sarcastic. Lot of that in here.
They're good heads but I think everyone is in concurrence if you need new pistons anyway, go with the a460.
Post  richter69 October 15th 2013, 11:13 pm
IDT-572 wrote:A heads..............Twisted Evil
I may just skip the A heads when the time comes and do a C.........
Post  cool40 October 15th 2013, 11:18 pm
Baller........Razz
Post  richter69 October 15th 2013, 11:37 pm
dont worry, i gotta run this junk for another season or two........ budget baller..........
Post  v-twin October 15th 2013, 11:47 pm
Okay the jokes on me. I'm glad some one besides me is running these heads. youtube Bristol 2013 mustang wheelie bounce
v-twin
v-twin
Post  dfree383 October 16th 2013, 12:34 am
Got that right
Yep......lol!
Post  windsor October 16th 2013, 8:44 am
dfree383 wrote:
Got that right
Yep......lol!
Especially with a hydraulic roller.
