How does hot weather affect stall?
Can't seem to get a handle on my 60' these days., and I'm wondering if anyone has found that as the air goes in the crapper ( HOT ) and the motor HP and torque falls off, the converter seems tighter ? I'm leaving on the same chip 5600, and in good air the converter stalls at 5800, is it possible that in bad air I could lose a few hundred RPM's of stall and be leaving right on the lock-up thus creating no flash in the converter and therefore no hit on the tires? Seems as though shes just not planting the tires. Chassis been scaled out and leaving straight, Rebuilt all four dbl. adj. shocks but adjustments have no effect, new springs, tires are fairly new 30 passes. Does anyone keep 2 converters one for hot weather & one for cool weather? Any Ideas????
trabdady- Posts : 12
Re: How does hot weather affect stall?
junk air = less power = less stall.
that and the hot track temps will affect 60' also.........wheelspin wont load the converter as much...............it just all goes to hell in the hot hot weather................
x2,we just had a good example of it a few weeks ago,lol. i'd say you could drop your rpm some and pick up 60' on the hot track.my 60'was 1.24-1.26 in the hot afternoon and 1.19 after dark.
» stall speed Vs. stall ratio ...?
» rpm vs cylinder pressure
» advanceing camshaft . does it affect ignition timing?
» When ordering a converter how much does the truck weight affect it.?
» Tornado on the ground !!!!!
