Time to get to work
Time to get to work Empty Time to get to work
Post  Mike R July 13th 2012, 11:48 pm
Well the weather has finally given me a break. The temp dropped to 70 tonight so I took advantage of it and hit the wagon hard. I got the interior out, all the under coating , sound deadner and seam sealer out and after some checking the fox body mini tubs are an exact match for the Fairmont. I've got a family reunion tomorrow so if the weather holds I'll be cutting it up on Sunday. I'm tired of reading about everyone else having fun, I want some too.
Time to get to work Empty Re: Time to get to work
Post  ThndrChkn July 15th 2012, 12:48 pm
Well then get off the computer, and get to work. Razz
Keep us posted.
ThndrChkn
ThndrChkn
Post  dfree383 July 15th 2012, 2:23 pm
Cool post some pictures
Post  jbozzelle July 16th 2012, 11:29 am
What minitub kit are you using? I've got most of the tubs cut out of my Futurs from years back and am picking up parts slowly to finish it... If I remember right I had a 29x10.5W on a 10" wheel mocked up under it and had room for more...
Post  Mike R July 16th 2012, 6:38 pm
I've got Wolfe mini tubs, off set lowers and semi stock upper spring mounts
Post  jbozzelle July 16th 2012, 9:37 pm
What size wheel/tire?
Post  Mike R July 17th 2012, 7:31 pm
I've got a set of 28x13.5 ET Streets on 15x10 with 7.5 bs and a set of 28x12.5 ET Streets on 15x10 with 6.5 bs, I'll run which ever fits I can't say for sure but I believe my rear end has been narrowed 1.5 per side. I can't decide if I want to use the spring relocators and small diameter springs or go with coil overs since I have to move the shocks inside the frame rails. It's still HOT as hell and after working in it all day I don't have much left to work after I get home, it's tough getting old.
