carb size recommendation
its time to replace the windsor engine in my fox
the motor I am installing is a 545 with P51 heads' cam is a Kasse spec. comp solid roller valve lift 757/751 gross
tappit duration @ .020 lift is 306/322
duration @ .050 273/284
lobe seperation is 110.0
what size carb should I use? I have a 1050 gas domi and a 1250 APD alky domi. and a 1400 SV1 or should I use something else?
also I need recommendations for front coil over spring rates. i have 150 lb springs in it for the small block
Larry Williams- Posts : 884
Re: carb size recommendation
I would contact Prosystems and let them tell you if the SV-1 will work. I love mine!
514Fox87- Posts : 436
i would say time slips would show something like 1150 or 1250 best
jc10000rpm- Posts : 193
» Exhaust Size Recommendation
» Alcohol Carb recommendation
» Carb question and recommendation
» carb size?
» engine tec
» carb size?
» engine tec
