94-04 mustang front brake upgrade
94-04 mustang front brake upgrade Empty 94-04 mustang front brake upgrade
Post  dirt_worker August 2nd 2012, 7:30 pm
Anybody ever used these calipers from ssbc?
I'm almost finished installing the mustang based strut frontend on my 67 f100.
after researching calipers, master cylinders and pedal ratio I found I need more caliper surface area to better whoa up my heavy truck. (surprizingly enough the 02 mustang dual piston calipers I intended to use have a good bit less surface are than the single piston f100 calipers I took off)
here's the link:
http://www.ssbrakes.com/commerce/detail/index.cfm?nPID=9433
is there a better bolt on 4 piston caliper upgrade for the 94-04 mustang for less money?
dirt_worker
dirt_worker
94-04 mustang front brake upgrade Empty Re: 94-04 mustang front brake upgrade
Post  jasonf August 2nd 2012, 9:18 pm
What size front wheels do you have? The cheapest way used to be the cobra brake upgrade but you need 17" wheels to clear the 13" rotors.
http://www.fordmuscle.com/archives/2005/02/BigBrakes/index.php
http://www.latemodelrestoration.com/item/SVE-2300K/1994-04-Mustang-Sve-13-Inch-Front-Cobra-Style-Brake-Kit
If you look around fleebay you can pick stuff up for less $$ as well.
Post  Mustang-junky August 3rd 2012, 8:39 pm
I have the 13" Cobra stuff on my '79 mustang. Got the calipers from Advance Auto for small money. The hardest part for me to track down was the caliper brackets. Parts stores have the same bracket listed for the GT and Cobra, but they are different. Spindles are the same for the GT and Cobra brakes.
Jess
Mustang-junky
Mustang-junky
Post  dirt_worker August 3rd 2012, 9:56 pm
whats special about the cobra calipers? I've got the pbr dual piston calipers already. from what I've found both pbr and cobras have the same 1.77" dual pistons, is that true?
dirt_worker
dirt_worker
Post  jasonf August 3rd 2012, 11:20 pm
The cobra calipers are made by PBR.
The next step could be the cobra R brakes but they are more chingola. Once again they can be had for much less than the kit price.
http://www.americanmuscle.com/brembo-mustang-brake-kit-2000-cobra-r.html
If I recall I paid about $750 for the two calipers from Vintagevenom.com and I bought the rotors of fleabay. Vintage venom had some really great tech support so you could call them and even if they can't help you out they might be able to point you in the right direction. The guy I talked to there was/ or is a Ford brake engineer and was very knowledgeable.
Edit: I just seen on their site they have 14" kits now...
94-04 mustang front brake upgrade IMGP4170
