Comp lifters
+11
bosshoss
Mark Laczo
powerstrokeace
QtrWarrior
soupbean
15 posters
Page 1 of 3 1, 2, 3  Next
Comp lifters Empty Comp lifters
Post  soupbean August 4th 2012, 9:56 pm
Comp lifters Lifter
Look what I found today. Funny thing is, there are 17 needle bearings that make up a comp roller lifter. Not ONE inside the engine. Hmmmmm.... Guess that's why you shouldn't buy used engines!
soupbean
soupbean
Comp lifters Empty Re: Comp lifters
Post  richter69 August 4th 2012, 10:02 pm
well that dont look good.....
Post  soupbean August 4th 2012, 10:15 pm
No sir, the worst part is the bouncing around of the roller tip scored the cylinder walls up pretty deep. I think the block is trash.
soupbean
soupbean
Post  bbf-falcon August 4th 2012, 10:26 pm
Comp lifters and LARGE rollers scare me alot lately Shocked affraid
Post  richter69 August 4th 2012, 10:32 pm
how many runs on um?
Post  cool40 August 4th 2012, 10:38 pm
so....you think somebody got the bearings out before you bought the motor?
Post  soupbean August 4th 2012, 10:58 pm
cool40 wrote:so....you think somebody got the bearings out before you bought the motor?
Ding Ding! We have a winner!
soupbean
soupbean
Post  Lem Evans August 4th 2012, 10:58 pm
I suspect there are 17,000 pieces of needles inside the engine.
Post  QtrWarrior August 4th 2012, 11:01 pm
Lem Evans wrote:I suspect there are 17,000 pieces of needles inside the engine.
X2
Ground to a powder in the bottom of the pan.
QtrWarrior
QtrWarrior
Post  richter69 August 4th 2012, 11:02 pm
ground to a pulp....... thats a hell of a thing to pull the lifters out and remove the needle bearings..........
Post  Lem Evans August 4th 2012, 11:02 pm
X2
Most likely in the oil filter. Wink
Post  richter69 August 4th 2012, 11:07 pm
I found a roller lifter needle bearing stuck in the base oil pump gears in a 6.0 yesterday........ I bet it costs more to fix........ Wink
Post  soupbean August 4th 2012, 11:11 pm
Lem, I hope you are right (And I need parts by the way, call you Monday), the guy I bought the engine from seems like a truely good guy. The problem was when I bought the engine from him, I pulled the pan and there was a needle bearing on the pick up. He had an issue with some previous roller rockers that spit out needle bearings, had Jet Boat Bob go through it and freshen. He said it must have been a bearing that wasn't caught in the clean up hidden some where which made sense but when this happened I became very suspcious. But if you are telling me that all those needle bearings can be chewed up into small particles, that makes me feel much better and feel bad about my assumptions.
soupbean
soupbean
Post  Lem Evans August 4th 2012, 11:13 pm
bbf-falcon wrote:Comp lifters and LARGE rollers scare me alot lately Shocked affraid
These lifters were never exposed to a large roller cam.
Post  soupbean August 4th 2012, 11:24 pm
And unfortunately never will, but I suspect the next set will be Twisted Evil
soupbean
soupbean
Post  Frank Merkl August 4th 2012, 11:28 pm
seen 3 different motors this year with the same problem ( all fords)with the lifters and all comp cams lifters all with less than 70 runs on the lifters and one only had 25 passes !! the needles turn to dust!!
Post  richter69 August 4th 2012, 11:29 pm
I always use these types of things as an excuse to go bigger and badder........ Wink
Post  soupbean August 4th 2012, 11:31 pm
Another funny thing is I met a feller that browses this site a few weeks ago at a track in South Carolina and he was talking about all the bad things he has heard about Comp lifters...
soupbean
soupbean
Post  soupbean August 4th 2012, 11:33 pm
Yes Jon you are right! Lem has been saying this thing wants pistons and a real camshaft so I guess here we go!
soupbean
soupbean
Post  richter69 August 4th 2012, 11:36 pm
boogity boogity......... Smile
Post  soupbean August 4th 2012, 11:39 pm
richter69 wrote:boogity boogity......... Smile
Guess I need to step it up anyway so I can come play with y'all at the next bash.
soupbean
soupbean
Post  soupbean August 4th 2012, 11:41 pm
Think that "green oil" would prevent this? Very Happy
soupbean
soupbean
Post  cool40 August 4th 2012, 11:44 pm
soupbean wrote:Think that "green oil" would prevent this? Very Happy
no,but it damn sure wont hurt. Very Happy
Post  Lem Evans August 4th 2012, 11:51 pm
17,000 1/4 mile passes at least with pro comp lifters and green oil. Idea
Post  powerstrokeace August 4th 2012, 11:54 pm
Lem Evans wrote:
X2
Only if it a JOMAR........
Ace
powerstrokeace
powerstrokeace
