Starter-bellhousing trouble
J R
Starter-bellhousing trouble Empty Starter-bellhousing trouble
Post  J R October 1st 2009, 4:27 pm
Do we have to have a bigger starter for the JW bellhousing thanks.
J R
J R
Starter-bellhousing trouble Empty Re: Starter-bellhousing trouble
Post  the Coug October 1st 2009, 4:38 pm
nope stock or aftermarket worked on mine...
Post  ThndrChkn October 1st 2009, 4:43 pm
Roger that... I'm running a stocker on mine...
Doug... Cool
ThndrChkn
ThndrChkn
Starter-bellhousing trouble Empty Ultra bell
Post  Wheelie58 October 7th 2009, 9:53 pm
J R wrote:Do we have to have a bigger starter for the JW bellhousing thanks.
I can give you all of the info you need on this ..and keep you from spending money experimenting....
call me..
I am in Alpharetta...
Keith - 678-458-2033
www.KeithFulpMotorsports.com
Wheelie58
Wheelie58
Post  ThndrChkn October 8th 2009, 9:20 am
I believe the 1st 2 replies have been there... Wink
Doug... Cool
ThndrChkn
ThndrChkn
Post  Wheelie58 October 8th 2009, 8:03 pm
1bad521 wrote:I believe the 1st 2 replies have been there... Wink
Doug,
No doubt there....and absolutely no disrespect...I just noticed that he was in my neighborhood....
just tryin to help a BBF brother....
thanks,
Keith
Doug... Cool
Wheelie58
Wheelie58
Post  AlkyPinto October 8th 2009, 8:21 pm
I use a stock 460 style starter on my JW Ultrabell
HOWEVER on my Ultrabell, JW rotated the starter
position a little. Maybe 10-15 * or so. So if you
are using an OEM backing plate, the backing plate
stater holes dont line up. In fact the OEM backing
plate covers the JW Ultrabell starter holes completely.
Luckly I noticed it and redrilled the backing plate
before I put it on the motor. Might be a hassle doing
it in the car??? So check your Ultrabell against your
backing plate first.
AlkyPinto
AlkyPinto
http://www.RichKentRacing.com
Post  J R October 8th 2009, 9:52 pm
thanks guys,we took a starter off a lol 351w just for cranking but getting a new one when go to the track.
J R
J R
Post  ThndrChkn October 9th 2009, 12:44 pm
Doug... Cool
Doug,
thanks,
Keith
None taken Keith, N/P... Very Happy Very Happy Wink
Doug... Cool
ThndrChkn
ThndrChkn
Post  mico October 12th 2009, 12:56 pm
Like others have said a stock starters works.
I had the starter bolts work loose a couple times so I put studs in the bellhousing. They have never come loose since. Makes putting the starter in a lot easier as well.
mico
