Trailer Winch
+14
yellowhorse7
61coon
Barney
bigblok2000ranger
valleydawg
18 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Trailer Winch
I've got a Superwinch S4000 in my trailer. Mounted under the cabinets with an oval hole in the toe board for the cable. Winch stays out of sight and out of the way. Works great. Best thing I did for mine was buying a wireless remote. It uses a key fob with in/out buttons. Much easier than a cable remote for a one man operation. With a 28' trailer plus a 7' ramp door the 25' wire remote cable just wasn't long enough. Just hit the button with one hand and steer the car with the other.
Mine is mounted with the bolts going through the floor and through a 3/16" X 12 X 10 steel plate on the underside. I cut the plate so it just fits between the floor joists. The plate and the winch sandwich the 3/4 plywood floor. I thought about welding in some bracing until I realized that the winch itself only comes with 2 bolt holes to mount it. 3/8 bolts are all that hold it down. Figured they would break before it could pull that plate through the floor. 7 years with the winch so far it's held fine mounted like that.
Re: Trailer Winch
David Cole wrote:I've got a Superwinch S4000 in my trailer. Mounted under the cabinets with an oval hole in the toe board for the cable. Winch stays out of sight and out of the way. Works great. Best thing I did for mine was buying a wireless remote. It uses a key fob with in/out buttons. Much easier than a cable remote for a one man operation. With a 28' trailer plus a 7' ramp door the 25' wire remote cable just wasn't long enough. Just hit the button with one hand and steer the car with the other.
Is she a super winch and did you get her from Rick James?
Re: Trailer Winch
I have a 12,000 Gorilla Winch I picked up out of Harbor Freight Catalog. 550.00 with Wireless remote.
Dan
Dan
Re: Trailer Winch
TRUKPULR wrote:I have a 12,000 Gorilla Winch I picked up out of Harbor Freight Catalog. 550.00 with Wireless remote.
Dan
The wireless remote I bet is nice. My control cable is not long enough when I am by myself.
Re: Trailer Winch
Just a very freaky winch.
Re: Trailer Winch
My control cable is not long enough when I am by myself..
......................sounds like a personal problem
Re: Trailer Winch
richter69 wrote:My control cable is not long enough when I am by myself..
x2
Re: Trailer Winch
^^ What he said.................. why does the cable need to be soo long when you're alone??? Too long a cable is like a limp dick......... ya can't beat it
Boo Boo
stangr8cr- BBF CONTRIBUTOR
Re: Trailer Winch
Ok you winches that's enough, we done jacked up another thread
Re: Trailer Winch
Boo Boo
Re: Trailer Winch
Blake is a personal friend of Rick James....talks to him most every day. You guys better back off or Rick may just pay you a visit
Re: Trailer Winch
Your lucky Nick don't give you a frickin warning!!IDT-572 wrote:Ok you winches that's enough, we done jacked up another thread
56Tbird- BBF CONTRIBUTOR
Re: Trailer Winch
I still slip those Dave Shappell disc's in once in a while. They are classics FO SHO
Page 2 of 2 • 1, 2
Page 2 of 2
