c6 shifting problem
c6 shifting problem Empty c6 shifting problem
Post  bigunitmudracing August 19th 2012, 1:10 am
Just had my C6 rebuilt... with 5clutches instead of 3 and 6pinion planetary's and e40d first and second gear with roller bearing shaft...
tci manual valve body ( no trans brake)
and the second gear servo
Problem...
first to second gear takes over 1 second.... it seems like forever. Its a full race truck..
Can it be adjusted??
bigunitmudracing
bigunitmudracing
c6 shifting problem Empty Re: c6 shifting problem
Post  res0rli9 August 19th 2012, 11:04 am
You need to call Doc. Frank Smile
Post  whitefield August 19th 2012, 3:33 pm
Servo along with vb issuses and some clutch pack clearance issuses sounds like to me.
Is this the same servo that they had a hard time getting out or is it a new one ?
whitefield
whitefield
Post  bigunitmudracing August 19th 2012, 8:55 pm
same servo. the seal got all chewed up and thats why it stuck. now. i talked to my rebuilder and he told me that he left the outter seal of the servo off so that i would get more pressure on second gear....
his told me to pull out the spring now so it works faster without the seal... or we can put the seal back on it ...
Love to hear what you think!!!
bigunitmudracing
bigunitmudracing
Post  whitefield August 19th 2012, 9:41 pm
leave the seal on it and put a stiff spring in it ! Do not take the spring out ! If you were not so far away I would come fix it for you. Sorry you are having such bad luck.
whitefield
whitefield
Post  bigunitmudracing August 19th 2012, 10:00 pm
I dont know what these guys are thinking... they build me a trans just like this 2 months ago for another truck i built and that one works great and they put the same parts in it and didn't take anything out....
bigunitmudracing
bigunitmudracing
