c6 shifting problems
I drove my car today for the first time. The trans has a manual reverse transbrake,. I don't have any fire going to the brake. 5500 stall it starts off in first I assume fine and it shifts to 2nd and 3rd also but when shifting to 2nd and 3rd each hits like a down shift.
Thanks for any info
Thanks for any info
tconnection- Posts : 866
Re: c6 shifting problems
This is a Merkle brake. For sure im gonna pm him. Im posting this to see if anybody has ran into this problem and was able to fix it without having to send it to Canada if its the valve body.
Thanks for any info.
Not quite sure what you mean " Hits like a downshift " . You mean it shifts hard? What is the rest of the trans like ? Was it built to Franks specs?
Gregaust- Posts : 625
It a Frank brake. Well I was kinda cruising down the road and when I go to 2nd it shifts like a hard hit. May b normal I dont know. It stays in gear though.
[quote="tconnection"]It a Frank brake. Well I was kinda cruising down the road and when I go to 2nd it shifts like a hard hit. May b normal I dont know. It stays in gear though.[/quot
Thats a good thing= no slipping
res0rli9- BBF CONTRIBUTOR
I think I can explain it better. Ok, example! Say you are in 3rd gear and you down shift to 2nd. That bump that you feel, that's what I feel when I up shift. It don't feel like it bump me forward it feels like it bump me back.
Thanks again
Thanks again
downshifts are slow on my vb's , its part of the design so there is no flair on the up shifts . If in doubt recheck you shift linkage adjustment if your not getting clean upshifts as the linkage has to be dead bang on ! and a sloppy cable will give you nothing but grief ! check the backlash on the cable ,over .060" is to much
Frank Merkl- Posts : 1524
or if it's just the 2-3 shift the 2nd gear servo is hanging in the case because it's to tight in the bore
» C6 shifting problems.
» C6 not shifting into 2nd----sometimes
» Shifting by Time/RPM
» C6. Slow shifting
» c6 shifting problem
» C6. Slow shifting
