what needed
manofmerc
quick 52
what needed
I have a truck that run the 1/4 in 11.50's and would like to pick a couple more ten's like 11.20's. its heavy at 3870 how much more power is need for this.
quick 52- Posts : 612
Re: what needed
up the jets in the plate a few sizes or so that otta do it................
Re: what needed
on hose im there plus im talking motor
More info
Tell us more about your combo so we can give you some ideas .Doug 67 comet 7.13 in the 1/8 466 cu.in.
manofmerc- BBF CONTRIBUTOR
Re: what needed
its a 472 with kb pistons, stock rods, stock crank, a429 heads, victor intake, 950 proform carb, 258 258 615 615 solid flat cam, 4000 stall, 3.89 gear mt 275x15x60 dr, cal trac's. truck has run a best of 11.43 @ 117 1.51 60 on motor i do have nitrous also with a 150hp hit its in the 10's. truck runs most the time hi 11.50's low 60's would like to be in 20's on motor
Re: what needed
Cam upgrade would help some IMO
Any porting done to the Heads and Intake?
Hows its 60' times? Little more gear maybe? A Little looser convertor would help it to.
Re: what needed
1050 carb, more split in the cam and more lift, and narrow the separation.
Then match the converter to about 200 rpm above the torque peak.
Re: what needed
X2IDT-572 wrote:1050 carb, more split in the cam and more lift, and narrow the separation.
Re: what needed
Quick
What kind of truck is it & is it a Pump Gas Combo. I am currently building a 502 CID for my 1970 f-100, hoping to get in the 11's on Motor . I was running a 466 CID best time i had with it was a 11.73 @ 115 60' was 1.68 with a 125 shot of Juice. On motor best time was 12.40 @ 111 60' was 1.76.
OldRed70- Posts : 155
Re: what needed
its a 1952 f1. do you think a dom. will work on the streets its a street rod first that i race. the 60' are good with a best 1.50 but stays mid to hi 1.5's how much cam do you think i can go with it being a street rod
Re: what needed
its a pump gas motor runs on 87 but used 93 when racing it the motor is 10.1 to 1. its more of a street rod than a race car its has a overdrive trans that let's me drive on the eway 70mph is 2300 rpm's. i raced it on drag week 2009 and 10 in 2010 i average 11.67 for the week and made it to the semi. before red lighting had them beat just need to drive down the track my luck the winner was hurt. but won quickest street rod both year'sOldRed70 wrote:Quick
Re: what needed
That is a nice truck and pretty fast for a street truck!
jasonf- BBF CONTRIBUTOR
Re: what needed
Dale definetly has a nice truck there I seen it many of time
Dale.........get Blake to spec one of his "Barb Wire Series" cams and rub on those heads over the winter
