13.5cr alum cobra jet 466
samiam
tconnection
13.5cr alum cobra jet 466 Empty 13.5cr alum cobra jet 466
Post  tconnection August 25th 2012, 12:34 am
The initial timing was at 50 unless the light was wrong and put it at 18 it spit back, wouldnt even crank then put it at 30 and it cranked easier than the 50. What's going on here? Thanks for any info.
Thanks again
tconnection
13.5cr alum cobra jet 466 Empty Re: 13.5cr alum cobra jet 466
Post  dfree383 August 25th 2012, 1:12 am
What Distributor? Is it Locked Out?
Have you verified the timing mark's are correct?
Is the Distributor Installed Correctly?
Post  samiam August 25th 2012, 1:30 am
Balancer may have spun on the hub
samiam
samiam
Post  tconnection August 26th 2012, 1:19 am
MSD and the number one on the cap is at like 9 or 10 o'clock. And it's not locked out and still has stock springs.
The piston at top dead center matched up with the pointer and the zero on the balancer.
It's a fluidamper.
tconnection
Post  dfree383 August 26th 2012, 3:25 am
If its a race car... Lock it out.
and start with 32 Degrees (Total) and see how it runs.
Post  Nevs August 26th 2012, 11:25 am
dfree383 wrote:If its a race car... Lock it out.
I agree with Dave, you certainly don't want or need 50*...
Post  maverick August 26th 2012, 8:19 pm
Do you have a start retard of any kind,,,add on or built in your ign box?
Post  bbf-falcon August 26th 2012, 10:16 pm
Might try another light for a second opinion also.
Post  cool40 August 26th 2012, 10:20 pm
if you run it at 50* you'll have problems. affraid
Post  tconnection August 27th 2012, 12:26 am
This is a motor that belongs to a fellow i know. I kinda stepped in on what somebody has already been working on. And is there any instructions on how to lock out a msd dist.
tconnection
Post  dfree383 August 27th 2012, 12:33 am
http://www.msdignition.com/instructiondownload.aspx
