Question about Milodon 4bolt main caps
Has Anyone used the Milodon 4bolt main caps ? What are the pros and cons ?
Are there a splade cap for a D1VE block ?
whitefield- Posts : 2244
Re: Question about Milodon 4bolt main caps
I believe the milodon caps are intended to be used on a DOVE Block.
BT make caps for a Thin rail block
Red and I have done both, give him a call, he would be happy to help you....................
Type "Milodon" into the search engine and you'll find a couple of threads with good info on them.whitefield wrote:Has Anyone used the Milodon 4bolt main caps ? What are the pros and cons ?
Paul
Paul Kane wrote:Type "Milodon" into the search engine and you'll find a couple of threads with good info on them.whitefield wrote:Has Anyone used the Milodon 4bolt main caps ? What are the pros and cons ?
Paul
Thanks Paul Thats what I have been doing all morning ! I have found out I have a lot to learn . Thanks to all of the responses and this seems to be a hot topic .
My 557 made 860 hp and a D1 block with Cat splayed main caps, I paid 53 bucks for them. Ran for several years and several dyno sessions and everything looked perfect when I tore it down and sold it.
Shifted it at 7100-7200 and more than one rip to 8200.
Its a little more work to install them on a D1 block but it is doable.
The D1VE blocks are all I have left so looks like that maybe the direction I go in.!
D1VE block seems to be the most plentyfull blocks and all the others are rare or hard to find !
Thanks Mike
Thanks Mike
» milodon 4 bolt main caps question.
» 4bolt main caps
» How much does it cost to get 4bolt caps get put on?(roughly) and what can my 77 460 block with center 4bolt caps block handle?
» Drill bushing for Milodon main caps
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» 4bolt main caps
