D/E460, A460
D/E460, A460
I am building a 429/460 for a FFR cobra replica. My short block was professionally built. I am looking to use 4.400 with .060 compressed thickness cometic head gaskets. As I am looking some applications are for A460 or D/E460 blocks. This is an original circa 73 block. I don't want to get gaskets that have water passages different or whatever. Can someone explain these differences to me and possible sources for the correct gaskets or if they are interchangeable. Thanks for your time. Nick C.
Nick C- Posts : 6
Re: D/E460, A460
You need to get gaskets for a regular 429/460.... Those Parts are specific race parts.
Ford racing offers a nice complete gasket set. Lem should be able to hook you up.
Re: D/E460, A460
Nick C wrote:I am building a 429/460 for a FFR cobra replica. My short block was professionally built. I am looking to use 4.400 with .060 compressed thickness cometic head gaskets. As I am looking some applications are for A460 or D/E460 blocks. This is an original circa 73 block. I don't want to get gaskets that have water passages different or whatever. Can someone explain these differences to me and possible sources for the correct gaskets or if they are interchangeable. Thanks for your time. Nick C.
I assume your head gasket decision was made during block and cylinder head prep. A simple Fel-Pro or Ford part with Teflon sealant would be fine with your street application. If your block and cylinder head mating surfaces have been prepped for a steel layered type of gasket, then I guess a steel layered gasket will work too.
Dave.
LivermoreDave- Posts : 972
Re: D/E460, A460
Thanks for the info. My machinist had prepped the engine for cometic and suggested the .060. Appreciate the help Nick C
Nick C- Posts : 6
» Boost with E460 heads?
» E460 Heads For Sale
» E460 heads & block
» E460 Stainless Burns Headers
