Fox body brake Queston
dr's wife racing
Fox body brake Queston Empty Fox body brake Queston
Post  dr's wife racing September 6th 2012, 2:50 pm
I'm looking to change my fox body to a 5 lug set up on the front.Does any on know of a stock replacement rotor that is a direct replacement .I've been told a some yr of a mark VIIor a ranger ?????
dr's wife racing
dr's wife racing
Fox body brake Queston Empty Re: Fox body brake Queston
Post  bruno September 6th 2012, 3:03 pm
5-lug brake rotors from a late 80's Lincoln Mark VII in the front
http://WWW.CKRME.COM
Post  bruno September 6th 2012, 3:05 pm
also depending on which wheel there could be fitment issues this is due to the fact that the Mark VII rotor hat is too tall and the dust cap on the rotor extends too far out. This prohibits the center cap of the wheel from being installed. There are two solutions to this problem. The first is to install ½" wheel spacers behind the front wheels to allow more clearance for the dust cap. This also requires that longer wheel studs be installed on the front rotors for safety
Post  bruno September 6th 2012, 3:07 pm
here is some more info
http://www.mustangcentral.net/tech/5lug.html
Post  dr's wife racing September 6th 2012, 3:18 pm
Thank you sir that is what I'm looking for.
dr's wife racing
dr's wife racing
Post  BigBlockRanger September 6th 2012, 4:15 pm
Mark 7 for 1987 & up V8 cars <-- use different spindles and struts
Ranger for all others exc SVO. All up to 1986 and ALL 1987 & up 4 cyl cars.
Post  Doug Rahn September 7th 2012, 4:30 am
I don't know if they still make them, but Power Slot did have a direct bolt on replacement 5 lug, 8118PSL & 8118PSR. Somebody may still have them on the shelf.
Post  whitefield September 7th 2012, 12:28 pm
Here is some help full info Very Happy
http://www.popsracing.com/tech/5lugconversionfox.pdf
whitefield
whitefield
Post  dr's wife racing September 7th 2012, 1:31 pm
Ok my car is a 88 orig 4 cyl car. Should use ranger rotors. Right? any yr. or motor combo?
dr's wife racing
dr's wife racing
Post  whitefield September 7th 2012, 1:58 pm
dr's wife racing wrote:Ok my car is a 88 orig 4 cyl car. Should use ranger rotors. Right? any yr. or motor combo?
Use 83 to 92 4cyl ranger rotors.
whitefield
whitefield
Post  whitefield September 7th 2012, 2:00 pm
Another link Have to do a little readin but some good info.
http://www.stangnet.com/mustang-forums/threads/the-ultimate-4-lug-5-lug-brake-conversion-upgrade-thread.801400/
whitefield
whitefield
Post  BigBlockRanger September 7th 2012, 3:42 pm
Might have to take a grinder to the edge of the brake pad backing plate if it touches the rotor hat. I had to on mine. No biggie.
Post  bigblok2000ranger September 8th 2012, 4:23 am
If you use the Ranger rotors use the Ranger bearing races with the Mustang bearings the Ranger rotor is ~1/4" larger than the mustang and may require a little loving with a grinder.
bigblok2000ranger
bigblok2000ranger
