T Brake Valve Body
T Brake Valve Body
Who has the best t brake for the C6. I want one but I don't want to have to push the button for Reverse. I am building a early bronco wit a 460. Its going to be kinda a all around truck. Want to crawl with it but also hit the local mudbogs. Just don't want to be on the side of a hill having to hit a button to back up.
Re: T Brake Valve Body
Frank Merkl! Build's his own, best C6 man around and he is a member here.
Here read this post and you will find him and his ph#.. and you can learn the C6 if you dont know it. show's how to build a bad ass C6
http://www.460ford.com/forum/showthread.php?t=113120
res0rli9- BBF CONTRIBUTOR
another vote for Frank.
Yea I was looking into his. I guess I need to call him. I don't need it for a little while I working on the susp and body right now. On his do you have to hold the t brake to use reverse. That the only feature I don't want. I know In the mustang I used to have had a PA trans brake and didn't have to but others some others you do.
I dont thank you do.
» C6 manual valve body with trans brake.
» TCIs trans brake valve body c-6
» Ford Motorsports C6 trans.brake valve body
» Fox body brake ?
» Fox body brake Queston
» Fox body brake ?
