msd chip
+9
dave d
bigblok2000ranger
342g
13 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: msd chip
You can test the resistance of all of the chips with a simple volt/ohm meter, just measure the resistance across the pins.
google for all of the resistance values and the coresponding rpm
or buy a adjustable chip for about 55.00. If the chips ohm out okay and you still have a problem, it is definately in the box.
yes they start about 200 before,just use a chip thats 200 rpm higher than you need
BOSS 429- Posts : 2372
here ya go guys
RPM Ohms RPM Ohms RPM Ohms
2000 1152 4500 3141 7000 5689
2100 1224 4600 3235 7100 5793
2200 1297 4700 3316 7200 5919
2300 1370 4800 3412 7300 6043
2400 1444 4900 3509 7400 6150
2500 1518 5000 3592 7500 6277
2600 1592 5100 3691 7600 6406
2700 1668 5200 3791 7700 6517
2800 1744 5300 3877 7800 6649
2900 1820 5400 3979 7900 6782
3000 1896 5500 4082 8000 6897
3100 1978 5600 4171 8100 7034
3200 2049 5700 4277 8200 7171
3300 2132 5800 4383 8300 7291
3400 2215 5900 4475 8400 7432
3500 2288 6000 4584 8500 7575
3600 2373 6100 4693 8600 7699
3700 2460 6200 4788 8700 7845
3800 2534 6300 4901 8800 7994
3900 2622 6400 5014 8900 8122
4000 2710 6500 5112 9000 8274
4100 2787 6600 5232 9100 8428
4200 2877 6700 5349 9200 8561
4300 2969 6800 5449 9300 8719
4400 3048 6900 5569 9400 8879
Re: msd chip
who need chips..........
Re: msd chip
I wonder how many guys are on there way out to their cars right now to check a few? lol
Re: msd chip
1º = 1000 ohms
2º = 2000 ohms
3º = 3000 ohms
4º = 4000 ohms
etc etc etc.
hope this helps somebody
2º = 2000 ohms
3º = 3000 ohms
4º = 4000 ohms
etc etc etc.
Re: msd chip
cool40 wrote:who need chips..........
havent used them in a long time
Re: msd chip
342g- BBF CONTRIBUTOR
Re: msd chip
yes , a bad chip can break up( limit rpm ) early
Re: msd chip
BOSS 429 wrote:yes , a bad chip can break up( limit rpm ) early
On the shifter?????
Curt- Posts : 2791
Re: msd chip
[quote="Curt"]
On the shifter?????[/quot
why not on a shifter also ? if it shorts thru the shifter? bad ground,its still conected to the box and senses rpm tells it when to shift,shifter has a + /- could be messing with the box, Ive seen stranger things
could be 2 problems
could be 2 problems
Re: msd chip
I guess so.
Harold, time to get into the 21st century and go digital
Curt- Posts : 2791
Re: msd chip
I'm with Harold i've still got chips, and Thanks Rich for the ohms chart nice thing to have around
dave d- Posts : 809
Re: msd chip
What about your tach? I have had tach go bad and cause my truck to act funny right before it shifted, I changed chips, shift lights, added grounds and anything else We could think of till we finally put in a borrowed tach and problem went away.
lghting94- Posts : 762
Re: msd chip
Electrical issues can drive you batty A simple loose ground can cause more problems than imaginable.
Re: msd chip
I called msd, the tech guy said a bad chip will do just as I explained, any time the rpm's get to that point it will break up, makes no difference that it is a shift chip, the chip comes into play any time the rpms get to that point, the activator doesn't know how many times the tranny is going to shift, could be a four speed, but when it gets to the point, the bad chip will f-up.
Re: msd chip
Well ,change the frickin chip!!! Pretty simple!! I'll bet it don't fix it though
56Tbird- BBF CONTRIBUTOR
Re: msd chip
56Tbird wrote:Well ,change the frickin chip!!! Pretty simple!! I'll bet it don't fix it though
Wait til I get back to the friggin track.
Re: msd chip
What is the difference between "Frikin" and "Friggin"?
Re: msd chip
I had the same thing happen to me tossed the chip and went back to running the number.
Harold, didn't we discuss that at Byron?
Re: msd chip
i think we both did at us43 late last year i think?IDT-572 wrote:I had the same thing happen to me tossed the chip and went back to running the number.
Re: msd chip
dave d wrote:I'm with Harold i've still got chips, and Thanks Rich for the ohms chart nice thing to have around
Your Welcome
Re: msd chip
I can't remember Blake, I was pretty well disgusted.
Re: msd chip
cool40 wrote:i think we both did at us43 late last year i think?IDT-572 wrote:I had the same thing happen to me tossed the chip and went back to running the number.
I wasn't having the problem at U.S43.
Page 2 of 2 • 1, 2
» Superchips 1700 Micro Tuner for 7.3 Powerstroke
» This is 8800 rpm in the chip
» What rpm chip should I be leaving with
» Doing it again in 10
» chip for a 97 f350 with a 460
Page 2 of 2
