Motor missing at higher RPM Maybe even just above an idle
Larry Williams
digger460
Motor missing at higher RPM    Maybe even just above an idle Empty Motor missing at higher RPM Maybe even just above an idle
Post  digger460 September 8th 2012, 9:21 pm
Seems like #3 and #7 are not firing. When we were at the track today someone had a temp guage and 3 and 7 were always cooler by 100+ degrees... New wires ,changed spark plugs, swaped spark plug wires, ckd valve adjustment, removed carb spacer,. Changed cap and rotor. I have all MSD ign. I pulled #3 spark plug and ckd for spark and was good. Anyone have any other idea what I could ck for.
digger460
digger460
Motor missing at higher RPM    Maybe even just above an idle Empty Re: Motor missing at higher RPM Maybe even just above an idle
Post  Larry Williams September 8th 2012, 9:57 pm
compression. I would do a leak down test
Larry Williams
Larry Williams
Post  dfree383 September 8th 2012, 10:47 pm
Lean condition?
When did you notice the change? What did you change?
Post  cool40 September 8th 2012, 10:48 pm
vacuum leak.
Post  Dave De September 8th 2012, 10:59 pm
Larry Williams wrote:compression. I would do a leak down test
X2
Do the leak down test. I had 2 cold holes and the leak down showed ring leakage that led to finding burned pistons. If I continued to run it #5 piston would have failed completely and ventilated the block.
Post  crittersf1 September 9th 2012, 8:34 am
Leak-down test will identify the problem.
crittersf1
crittersf1
Post  digger460 September 9th 2012, 7:16 pm
I did try a couple tank fulls of the Q16. And since than it hasn't run right. When I went to the Q16 I installed bigger jets.
digger460
digger460
Post  IDT-572 September 9th 2012, 8:17 pm
If you didn't step it up 8-10 you may have leaned it out and hurt something............
Post  digger460 September 10th 2012, 11:48 am
I went up from 84 to 96. Oh well, I'll get it taken apart in the next couple days and find out.
digger460
digger460
Post  IDT-572 September 10th 2012, 11:51 am
digger460 wrote:I went up from 84 to 96. Oh well, I'll get it taken apart in the next couple days and find out.
Let me know what you find...............
Post  digger460 September 12th 2012, 12:09 pm
I removed the heads and found nothing wrong. Valves look OK.. Pistons don't have any holes in them... I ckd the cam lobes and lifters on 5 and 7 and they looked Ok.
digger460
digger460
Post  dfree383 September 12th 2012, 12:24 pm
Check the pressures on the valve springs.
And check all the valves while they are out.
Post  HorsinAround September 13th 2012, 9:36 am
X2
X3
And if you still have the heads off, check the spring pressures as it's a good time to do it. Also, check all the push rods and rockers.
http://www.frontpagefab.com
