71 429 cobra jet
71 429 cobra jet Empty 71 429 cobra jet
Post  71cobra September 9th 2012, 5:50 pm
i have a 71 429cj in a 71 torino cobra.when i rebuilt the engine i kept it mostly stock used the original pistons,connecting rods,crank,heads.i used a little bigger hydraulic cam with new lifters and valve springs.when i turn the engine over even a half a round i hear clicking it sounds like lifters are leaking down is this normal.
71cobra
71 429 cobra jet Empty Re: 71 429 cobra jet
Post  BOSS 429 September 9th 2012, 6:31 pm
have you pre lubed the engine( primed it) ? , did you set the lifters( rockers correctly?
Post  foxbigblock September 10th 2012, 10:30 am
BOSS 429 wrote:have you pre lubed the engine( primed it) ? , did you set the lifters( rockers correctly?
X2 It will tick without oil upon startup. Better to prime it especially for the sake of the new cam.
foxbigblock
foxbigblock
71 429 cobra jet Empty engine help
Post  71cobra September 10th 2012, 8:12 pm
I used engine assembly lube and primed the motor with the oil pump and set the rockers by the book and i have double checked them.i rebuilt the engine a couple of years ago and doesnt or never has any clicking when it is running.since then i start it on a regular basis but have not got it on the road yet still waiting for the body work and paint. but if somebody could tell me rocker adjustments i would greatly appreciate it.and i give it a try.thanks
71cobra
Post  dfree383 September 17th 2012, 2:28 am
Turn the motor over untill the rocker is closed and the lifter is on the base of the cam.
Tighten the rocker untill their is no slack in the pushrod and the 1/2 turn more (Its call preload)
Repeat 15 more times.
Post  71cobra October 4th 2012, 5:35 pm
when i adust the preload on rockers should i be able to spin the pushrods or does it matter.if i turn the engine over by hand even a half turn and stop i can here ticking like the lifters are leaking down.any help is appreciated
71cobra
Post  BOSS 429 October 4th 2012, 10:01 pm
which studs do you have pos+ stop,or adjustable?
