Always look your stuff over between races.......
+7
bigblok2000ranger
whitefield
psfracer
Treeyasoon
11 posters
Always look your stuff over between races....... Empty Always look your stuff over between races.......
Post  richter69 September 9th 2012, 7:27 pm
I was crawlng under the car hooking up my block heaters and happened to give the jam nut on the steering shaft coupler at the rack a twist with my fingers and noticed it was loose.........took it out and found this
Always look your stuff over between races....... E83db29a7e4a899c8c95270a1e9141cb
before yall freak out I have a stop collar on the shaft at the firewall so even if the set screw fell out the shaft cannot become disconected from the rack........but still
CHECK YOUR SHIT OFTEN!!!!! lol
Always look your stuff over between races....... Empty Re: Always look your stuff over between races.......
Post  cool40 September 9th 2012, 7:36 pm
you must'a used your "good arm" on that. Laughing mine has a bolt with safety wire through it.
Post  Treeyasoon September 9th 2012, 9:12 pm
richter69 wrote:I was crawlng under the car hooking up my block heaters and happened to give the jam nut on the steering shaft coupler at the rack a twist with my fingers and noticed it was loose.........took it out and found this
Was this a Flaming River unit, by chance?
Treeyasoon
Treeyasoon
Post  richter69 September 9th 2012, 10:15 pm
i think the joints were afco's, it will get a grade 8 bolt this go round lol.
Post  cool40 September 9th 2012, 10:23 pm
richter69 wrote:i think the joints were afco's, it will get a grade 8 bolt this go round lol.
you got any spare grade 8 bolts? tongue
Post  richter69 September 9th 2012, 10:25 pm
Its between my spare converter and camshaft........ I'll make a run to the hardware store tomorrow. Cool
Post  psfracer September 9th 2012, 10:27 pm
yep, crap on my car is always loosening up from time to time. Header bolts are my repeat offenders.
psfracer
psfracer
http://www.psfracer.com
Post  whitefield September 9th 2012, 10:29 pm
either way thats not good!
whitefield
whitefield
Post  bigblok2000ranger September 9th 2012, 10:31 pm
Funny you post this thread today. I was going through the lash on mine today and a few valvecover bolts were loose so started checking bolts and quite a few needed a little turn here and there. My steering shaft has smooth bore u-joints that are welded but also put a grade 8 bolts through them for extra insurance.
bigblok2000ranger
bigblok2000ranger
Post  richter69 September 9th 2012, 10:36 pm
my joints are welded and bolted also, the splined part that hooks to the rack just uses the set screw, this is the reason I made a stop collar at the firewall so just in case this happened.
Post  cool40 September 9th 2012, 10:38 pm
amature....... Razz
Post  richter69 September 9th 2012, 10:47 pm
bad decision maker........ Razz
and before Lem says it, "fabio welds his joints"................ironman
Post  cool40 September 9th 2012, 10:49 pm
richter69 wrote:bad decision maker........ Razz
are you bipolar Question
Post  IDT-572 September 9th 2012, 10:51 pm
you two need to take it outside...............
Post  56Tbird September 10th 2012, 12:14 am
IDT-572 wrote:you two need to take it outside...............
I concur Laughing cheers king
56Tbird
56Tbird
Post  dfree383 September 10th 2012, 12:28 am
He said "joint"..... drunken cherry
Post  richter69 September 10th 2012, 8:11 am
Its my thread superman.......... Razz
Post  Barney September 10th 2012, 9:17 am
I can't believe any bolt would have the nerve to loosen up on you! Wink
Barney
Barney
Post  bruno September 10th 2012, 9:22 am
Good morning everyone
http://WWW.CKRME.COM
Post  dfree383 September 10th 2012, 9:29 am
bruno wrote:Good morning everyone
Morning.... Shit..... its dinner time already... Your late !!! Sleep Laughing
Post  Barney September 10th 2012, 9:39 am
Good morning.
Barney
Barney
