c6 manual valve body,,, no gasket
ok i just got my tranny and it has no forward drive but it does have reverse. it was rebuilt but it has no valve body gasket. would this have anything to do with there being no forward? and were can i get a gasket for a manual forward shift pattern? oh it is a c6
ufospy- Posts : 13
Re: c6 manual valve body,,, no gasket
Most HP VB don't have gaskets. No forward gears would lead me to think that the Metal sealing rings are broke missing on the forward drum . The seals in the forward drum could also be cut when rebuilt left out or clutch pack learance way out of spec.
Manual valve could have been missed or not aligned correctly or the valve body its self is bad.
whitefield- Posts : 2244
Pressure test
Do a pressure test .On the drivers side at the front of the transmisson you will find a pipe plug it takes a 7/16 socket to remove .Get yourself a Transmisson pressure testing gauge with hose and fitting for the transmisson .After installation check and record pressures in all gear selections .P R N 3 2 1 .This will help you isolate the problem .A lot of c6 shift kits leave out the gasket between the seperator plate and the valve body most likely this isnt your problem .Find a local trans. shop they can help you might let you borrow a pressure gauge also .Doug
manofmerc- BBF CONTRIBUTOR
» Valve Body C6
» C6 manual valve body with trans brake.
» Fox Body doors with manual windows and locks
» Finally a valve cover gasket worth a damn............
» C-4 valve body
» C-4 valve body
