retard timing for nos???
if you take out 2* per 100 hp of nos where do i start from 36 total timing or from where my motor runs the fastet on hp
my motor runs faster on 32* then on 36* i dont know y it just does so for a 250 hit i pull 5 +1 to make 6* , the 1* just for safety , do i puul from 36 * or from 32* now i have the timing on 32* and pull out 8 for a 250 because my car is so wild when the gas come on
i can get on here much anymore but can someone have steve call or anserw this for me
9108407226 thanks logan
fastford600- Posts : 391
Re: retard timing for nos???
no set number, let the plugs and timeslip decide whatbtiming it wants............
cyl head, fuel type, tune up all play a role as do other things......
ok her is a lil info on my set up 598 ci bbf a460 heads and block 15 to 1 cr comp nitrous cam 831/831 just like i have it set up now it is a li dark on the plugs but i never fowl any out i run 6.5 psi of fuel @ flowing out the jet with the car started i run vp 120 gas
» Timing retard
» Retard timing
» Wtb timing start retard
» How much timing retard with 32 no2 jet? 12 degrees?
» Retard timing
