race fuel ??
+11
Tennessee Bullitt
D. Sea
westsideford
bigblockfox468
ThndrChkn
kjett
lghting94
Moodyblues
jason
15 posters
race fuel ??
Im looking to buy a barrel of 110 octane . We get it out of a pump up here and i wanna get away from that . What brand do you guys use?
jason- Posts : 220
Re: race fuel ??
118
Re: race fuel ??
I like the Sonoco stuff, mainly because I can get it by the sealed from Sonoco 5 gallon cans. The VP stuff is from a pump and I never know how long it's been there.
kjett- Posts : 1169
Re: race fuel ??
Renegade 110... IMO, it works better than the VP fuels I've tried, and definitely priced better, @ $355.00/55gals...
Doug...
Doug...
ThndrChkn- Posts : 2216
Re: race fuel ??
How long does this stuff stay good for when you open and close the drum on a regular basis or not regular basis? I kind of thought about getting a drum but just don't know if I would use it all in a season being I'm a part time weekend warrior
Re: race fuel ??
I've always been told that the effectiveness of the added octane will sort of drop off over time when the fuel is opened to the air. Not sure how true that is, but to keep on the safe side I try to get my fuel at 5 gallons at a shot. Then again, the people that told me that are the same place I get my sealed cans from, so they could be blowing smoke for all I know.....
kjett- Posts : 1169
Re: race fuel ??
I run the Sunoco 112.$7.00 a gallon. Dealer said it was good to 15.1 comp. The main thing w/race fuel is keep it in a cool place and out of the sun light. JMO
Re: race fuel ??
bbf-falcon wrote: The main thing w/race fuel is keep it in a cool place and out of the sun light. JMO
X2 Direct sunlight will cause the fuel to deteriorate and or breakdown... That's what I was told by my distributor, so while I'm at the track I store my jugs under my Super Duty...
Doug...
Re: race fuel ??
I've run Sunoco 112 & 110 and didn't see any differences. I went with 112 on hot days..
Laters
Laters
westsideford- Posts : 398
Re: race fuel ??
Sunoco 110 or 112 in my car. The last few years, I just buy it at the track, 5 or 10 gallons at a time. The price is much different than buying it in bulk.
D. Sea- Posts : 2768
Re: race fuel ??
Hey Doug how do you like the renagade fuel. I can buy it here too. You are the only one I have seen run it except these roundy round dirt track clowns out here.
Re: race fuel ??
I have been running the Renegade 110 all year with no complaints....out of the pump it is $6.39/Gal.Tennessee Bullitt wrote:Hey Doug how do you like the renagade fuel. I can buy it here too. You are the only one I have seen run it except these roundy round dirt track clowns out here.
I must admit...it has been in a brand x I've been driving, until I get the Yellow Car going again....But, it has been good fuel.
Treeyasoon- Posts : 759
Re: race fuel ??
I've been using the Renegade 112 in my 557 A-Head with no problems. I've used Sunoco, Torco and VP. The Renegade seems as good as any of them.
BigDave65- Posts : 567
Re: race fuel ??
Racing gasoline is supposed to have a shelf life of about 1 year in a sealed container. This is about 4 times as long as regular street gasoline.
DaveMcLain- Posts : 399
Re: race fuel ??
I have been using the renagade for five years, no problem, what you want to do once in a while, about every two weeks is squirt some wd-40 in the air jets, do this while running about 1500 rpm's, cleans the blue dye out of the carb.
342g- BBF CONTRIBUTOR
Re: race fuel ??
DaveMcLain wrote:Racing gasoline is supposed to have a shelf life of about 1 year in a sealed container. This is about 4 times as long as regular street gasoline.
Thanks Dave, I don't mean to be "anal" but a sealed container meaning never opened? How bout a 55 gal drum opened several times throughout the year? Good idea or bad idea
Re: race fuel ??
I buy a 55 gal drum or two every year and have never had a problem with fuel just close the drum back up after getting fuel out the original bungs have a seal on them.
lghting94- Posts : 762
Re: race fuel ??
[quote="lghting94"]I buy a 55 gal drum or two every year and have never had a problem with fuel just close the drum back up after getting fuel out the original bungs have a seal on them.[/quot
x2
x2
Re: race fuel ??
Treeyasoon wrote:I have been running the Renegade 110 all year with no complaints....out of the pump it is $6.39/Gal.Tennessee Bullitt wrote:Hey Doug how do you like the renagade fuel. I can buy it here too. You are the only one I have seen run it except these roundy round dirt track clowns out here.
I can't get it in the pump here, but X2 on the quality... I've used it the last 2 seasons without a complaint... It's a true 110 fuel also, with a motor octane level of 109-109.5... It's rated to 15:1 C/R and I know alot of guys at our tracks use it with no complaints...
Doug...
Re: race fuel ??
As long as you seal the drum back up tightly after you fill your jug I can't see it being any problem.
Re: race fuel ??
So are you guys keeping your drums in temperature controlled garages then? Would it still be good if I stored the drum in my non temperature controlled garage through the hot summer and cold winter months?
kjett- Posts : 1169
Re: race fuel ??
I leave my in a shed with no heat, or cooling," 0""problems.
» Race Fuel?
» vp race fuel ??
» Parts selection for blown application (Budget - Mild Boost)
» any luck with Race Pumps fuel pump ?
» Places to buy race fuel in NKY?
» vp race fuel ??
