Is a mid plate necessary?
I'm getting ready to mock up my engine and will be using a motor plate and a rubber trans mount with lateral stabilizers. Is a mid plate necessary? I've seen lots of big motor, big horsepower cars running just the front plate with out any problems, are they on borrowed time?
Mike R- Posts : 1381
Re: Is a mid plate necessary?
best way is to use a midplate in conjuntion w the front plate.....
I have a mid plate but was wondering how necessary it was after seeing so many others running with out one. I'm not against running one, it's just a lot more work if it's not really all that important.
Id run the stock mounts over a front plate only. Not only does the mp distribute power to the chassis more effectively it stiffens it up and also takes stress off the eng block and trans case.
Stock mounts are not an option, headers are for a motor plate. I have no problem doing the mid plate I just was wondering if it was really necessary. I only want to do this once so I may as well do it right. I understand and agree with you on the fact that it will stiffen the car up, just looking for other opinions. Thanks for the input John
with good limiters on it i think it'd be ok.i saw a very hot prostreet pull truck with no front plate or mounts,just a midplate
What thickness of mid plate? The one that I had on my puller was .062 but I always felt it was too thin even though it always worked. If a thicker one is used, does anything have to be done to the part of the converter that goes into the transmission housing?
Alan,
The BBF mid plates that I make are 12 ga steel, which is approximately .100" thick. This link will take you to a picture. https://www.429-460.com/t13876-bbf-starter-locator-plate-and-steel-mid-plate?highlight=starter+plate
I make them with the starter locator feature or with an open center like everyone elses.
In many cases, your converter pilot goes far enough in to the crank (or pilot adapter) to make the .100" OK. You really have to measure the parts that you have to make sure.
Thanks,
Keith Fulp
www.KeithFulpMotorsports.com
678-458-2033
Thanks,
Keith Fulp
678-458-2033
i dont know how thick it was but i'd say 3/8 or 1/2. it was a shock to see no front plate or mounts i guess it works for him,9500 rpm n/a!HorsinAround wrote:What thickness of mid plate? The one that I had on my puller was .062 but I always felt it was too thin even though it always worked. If a thicker one is used, does anything have to be done to the part of the converter that goes into the transmission housing?
I started out with a mid plate, car has always transfer power to chassis well and straight. I think they are well worth it.
67460- Posts : 384
Most mild steel mid plates I have seen (both hot rolled & cold rolled material) usually fall somewhere between .090" to .120" thick. Most regular aluminum mid plates ("regular" meaning it's only used as a mid plate, and not also a glide adapter too) usually are .250" thick. Alston used to sell a thinner aluminum mid plate years ago (they still might), but I have never seen anyone use the thinner aluminum ones (that I can remember anyway).
If you're going to go to the effort of installing a front plate, you might as well finish the job and install a mid plate too while you're at it.
DILLIGASDAVE- Posts : 2262
Well I'm convinced, Since I already have it I'll use it. I only asked because of all the cars I'd seen without one. I only want to do this once so I may as well do it right.I know I asked this before in the transmission section but got no answer, is there a specific rubber trans mount from any certain model I want to purchase? I'm going to be using a C-6 with the Fox double hump X-member.
» Looking for opinions on motor plate / mid plate vs solid mounts / no mid plate on a fox body .
» Cam thrust plate and water pump baking plate questions
» BBF Starter Locator Plate and Steel Mid Plate
» wtb front engine plate and mid plate
» Mid plate and motor plate for bbf ford-off set
