Header size ?
whitefield
Header size ?
Is there such a thing as header size to big ? say 2" versus 2 1/2 " ?
whitefield- Posts : 2244
Re: Header size ?
depends what its on
Re: Header size ?
466richter69 wrote:depends what its on
Re: Header size ?
i cant see where it would need a 2.5
Re: Header size ?
richter69 wrote:i cant see where it would need a 2.5
I don't think it would need them either, but was wanting to know if it would hurt power and torque to run a larger primary tube header ?
Re: Header size ?
I would think 2.5" exh. would hurt torque down low on a 4.390 bore 466.
Re: Header size ?
on a n/a setup i'd think too big would hurt torque but how big is too big? i was looking at 2 3/8 for the 605 but 2 3/8 to 2 1/2 was what i got. dynatec was one place i looked for info.........
Re: Header size ?
whitefield wrote:Is there such a thing as header size to big ? say 2" versus 2 1/2 " ?
Yes there is. It's been proven countless times on dynos everywhere. Chapters in books have been devoted to the subject.
Charlie
c.evans- BBF VENDOR SPONSOR
Re: Header size ?
c.evans wrote:whitefield wrote:Is there such a thing as header size to big ? say 2" versus 2 1/2 " ?
Charlie
Thanks for the info.
Re: Header size ?
You will lose exhaust velocity which will hurt during the overlap period when your starting your intake charge. (which hurts torque)
Unless it's a over the top 466, 2 inch is all that will be necessary.
Re: Header size ?
IDT-572 wrote:You will lose exhaust velocity which will hurt during the overlap period when your starting your intake charge. (which hurts torque)
I got to thinking what if you are running a 390 to 427 cubic inch engine would going from 1 3/4" to 2" primary headers be to large ?
Re: Header size ?
fwiw we run a 1 7/8 on our 306
Re: Header size ?
richter69 wrote:fwiw we run a 1 7/8 on our 306
Again, its about application. 6000 converter on a 306 sure, not a problem, but I would be willing to bet it would be just as fast with short tube 1.750 primary's on it.
Re: Header size ?
whitefield wrote:IDT-572 wrote:You will lose exhaust velocity which will hurt during the overlap period when your starting your intake charge. (which hurts torque)
If it's a full out race engine, no 2 inch will work. That's what I ran on the 414 Windsor with c-302 B's 6200 rpm converter. Shifting at 7200
Re: Header size ?
IDT-572 wrote:whitefield wrote:IDT-572 wrote:You will lose exhaust velocity which will hurt during the overlap period when your starting your intake charge. (which hurts torque)
Thanks, I think I am understanding this header deal better!
