header primary size on a 496
crittersf1
72mav
header primary size on a 496 Empty header primary size on a 496
Post  72mav October 1st 2014, 11:20 am
Hi guys,
Whats everyones thoughts about this? 2-1/8, or 2-1/4?
Engine is a 496 with SCJ heads with a 780/720 lift cam, compression will be 13+, stock valves with a 30degree back-cut on the intake valves. and a light cleanup on the ports for now.
Also planning on step design headers with merge collectors. I don't plan on taking it over 7200 RPM
Thanks.
Al
72mav
72mav
header primary size on a 496 Empty Re: header primary size on a 496
Post  rmcomprandy October 1st 2014, 12:23 pm
72mav wrote:Hi guys,
Thanks.
Al
Header tube size is mostly reliant upon RPM level and the cylinder size.
That header is to big unless you intend to be above 7,000 RPM most of the time.
Post  crittersf1 October 1st 2014, 5:08 pm
I'm with Randy. 1 7/8's are probably more than enough.
crittersf1
crittersf1
Post  dfree383 October 1st 2014, 5:11 pm
2" or 2 1/8" IMO
The bigger stuff will make bigger numbers upstairs.
Post  bbf-falcon October 1st 2014, 9:33 pm
Too much cam, headers too big, too much rpm.jmo
Post  68galaxie October 2nd 2014, 11:56 am
bbf-falcon wrote:Too much cam, headers too big, too much rpm.jmo
Too much cam? The OP did not supply any duration figures.
13+ CR and almost 500" can support a reasonably "big" camshaft for 7000 rpm limit.
2" header primaries will certainly work fine.
68galaxie
68galaxie
Post  the Coug October 2nd 2014, 2:04 pm
Personally Al I like the 2 1/8 I figure it is always better to have to much header than not enough....
Post  72mav October 3rd 2014, 10:53 am
No cam yet. That 780lift is a guess,  somewhere 700 and 800 for sure though.
Another small motor member here was running a735 lift @7100 RPM. thought...... Surprised
Btw, guys thanks for the info.
Regards.
Al
72mav
72mav
Post  D. Sea October 3rd 2014, 1:56 pm
2" Primaries IMO.
D. Sea
D. Sea
Post  the Coug October 3rd 2014, 2:04 pm
Rick why you say to much RPM? I spun my stock offset crank 7800 for 10 + years, and still looked like brand new when it went East to Kentucky
Post  bbf-falcon October 3rd 2014, 6:03 pm
Not saying it won't spin that far,just sayin imo that a pretty much stock scj head doesn't need that much cam or rpm's.
Post  dfree383 October 3rd 2014, 6:07 pm
bbf-falcon wrote:Not saying it won't spin that far,just sayin imo that a pretty much stock scj head doesn't need that much cam or rpm's.
That ain't no big cam..... Razz and shifting at 7200 is about right for an engine peaking at 6700.... What a Face
Post  the Coug October 3rd 2014, 7:13 pm
I think he has aluminum SCJs
Post  bbf-falcon October 3rd 2014, 9:15 pm
That ain't no big cam..... and shifting at 7200 is about right for an engine peaking at 6700....
Now i know why you race dyno's instead of cars. Razz
Post  rmcomprandy October 4th 2014, 10:11 am
bbf-falcon wrote:That ain't no big cam.....  and shifting at 7200 is about right for an engine peaking at 6700....
A step header with 2" to 2 1/8" primary tubes 31 inches long with a 3 1/2" diameter collector 17 inches long is the correct size for a 496 engine at 7,000 RPM ... on a dyno OR a drag race car.
USE a 2" straight tube header primary if the RPM level EVER drops below 5,000 RPM.
Post  dfree383 October 4th 2014, 9:21 pm
And that's what I learned from all the dyno time...... Rolling Eyes
When's the last time your car was on the track Rick? lol!
Post  bbf-falcon October 5th 2014, 9:36 am
One thing I learned in 40yrs of racing is that just because my engine will rev to 8k, that's no reason to shift it there . Rolling Eyes and a dyno is not a racecar.
