Header primary size - 547 A460 engine
Header primary size - 547 A460 engine Empty Header primary size - 547 A460 engine
Post  Rich Osmond August 29th 2013, 8:07 pm
Gents - I posted some Dyno results last week for my 547" A460 head engine. We only pulled the engine to 7000 rpm which is where we saw peak power of ~930 hp. My Fox mustang headers wouldn't fit the Dyno so we used a set of chassis headers which were 2 1/4" primary x 4" collector. The headers I have for my car are 2 3/8" x 4". Are the 2 3/8" tubes too large for my application (2900# non-nitrous car)? Thanks for you help.
Rich Osmond
Header primary size - 547 A460 engine Empty Re: Header primary size - 547 A460 engine
Post  Lem Evans August 29th 2013, 8:21 pm
2-3/8 is bigger than I'd want.
Post  bbf-falcon August 29th 2013, 8:49 pm
X2,the 2 1/4 is bout right.
Header primary size - 547 A460 engine Empty 547" headers
Post  Rich Osmond August 29th 2013, 10:29 pm
I am thinking the same. I have too much invested to give up power just to use a set of headers I have on hand... I will build new ones.
Know anyone looking for a nice set of HPC coated 2 3/8" Fox body headers? Headed to the "stuff for sale" section.
Rich Osmond
Post  rmcomprandy August 29th 2013, 11:41 pm
How long are those 2 3/8" primary tubes...?
IF they are made 28 to 31 inches long, you could sane yourself quite a bit of time by using a large step with 2" tubes for about the first third of the length and use most of your present headers; (unless the port itself would be to big for 2").
There would not be any difference in power to see with those 4" collectors.
Header primary size - 547 A460 engine Empty Headers
Post  Rich Osmond August 30th 2013, 8:15 am
Thanks everyone.
The headers will be in the 28-31" range you mentioned. IF I need to just build new headers what would you recommend? Primary tube size? Step vs no step? Collector size?
Thanks again
Rich Osmond
Post  rmcomprandy August 30th 2013, 4:58 pm
here is a whole lot more to it than maximum horsepower. RPM power range and almost everything about how the vehicle ACTS is very important.
The figures I gave you would act like a 2 1/4" straight tube header ... whether that 2 1/4" into 4" is the correct size or not is to be determined.
Post  v-twin September 4th 2013, 1:32 am
why not try what you have ? You may lose some bottom end , but that may help with starting line traction
v-twin
v-twin
Header primary size - 547 A460 engine Empty 547 Headers
Post  Rich Osmond September 4th 2013, 9:22 am
Thanks, I think that is a good point especially since this is going in a stock suspension 10" tire car. I think I will do that in the interest of testing, and then modify them over the Texas "winter" to include a 2 1/4" step. Thanks again.
Rich Osmond
